NEED HELP !!!!
Discussion in 'PT Cruiser' started by Randall, Dec 22, 2017.
  1. Randall
    Randall Member
    Dec 22, 2017
    1
    2006 pt cruiser will not start unless fuel is sprayed in intake but has fuel up to motor?any ideas also have to jump starter relay number 30 to 87 to get to crank
    18,326
    2,697
    Welcome to Allpar. Any fault codes? Any alarm or security system that may be armed and active? If you have good spark and fuel pressure, but have to jump the starter relay and the injectors aren't spraying then you may have wiring issues?
    An OBDII scan tool may show you useful information like cam/crank sensor states and if the PCM thinks that the car is in Park or Neutral. If the 'no crank and no fuel' situation happened at the same time, then they may be related.
    See p. 315 and p. 330 here for a 'No Start' and 'No Crank' condition:
    http://oskin.ru/pub/chrysler-dodge/manuals/Service Manuals/2004_PL_Neon/18623-pl-powertrain_sgmldiag.pdf
    This is for a '04 Neon, so there may be some differences. Wiring diagrams and pinouts in the back of the manual.
    Stephen M. Paraski likes this.
  3. djsamuel
    Sep 10, 2007
    2,685
    433
    Are you sure you have fuel pressure? If not, could be fuse that handles the fuel pump as well as the starter.
  4. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,823
    470
    First year for the TIPM. You might take some time and make sure all of the male and female leads in the connectors are clean and tight. Yeah, it takes a while.
