Need Some Help On My Omni 024
Discussion in 'L: Horizon/Omni, Rampage, etc' started by gearheadmike, Oct 31, 2016.
  1. gearheadmike
    gearheadmike New Member
    Mar 8, 2012
    8
    I just picked up a 81 omni 024 2.2 auto 70k original.
    I want to clean the engine bay up as much as possible and remove all unnecessary stuff like smog/emission/etc and all that. has anyome don it and what needs to be removed/blocked off
  2. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
    Illegal to do so. It's a violation of federal law. And pollution controls are not unnecessary. They help prevent lung disease and asthma attacks.
    Doug D likes this.
  3. gearheadmike
    Mar 8, 2012
    8
    i fig id remove as most the stuff dont seem to be working ait pump is seized the canister is cracked
  4. valiant67
    31,980
    11,552
    There is no non-computerized ignition that I know of for these cars. Your best performance will be to fix these things rather than remove them.
    Doug D likes this.
  5. gearheadmike
    Mar 8, 2012
    8
    isnt there a more simple ignition that dodge had with a little 5 plug connector? i remember doing something like that to my 80's diplomat that had the lean burn system when i removed it all
  6. valiant67
    31,980
    11,552
    There was for the slant 6 and V8s, nothing for the FWD 4 cylinders.
  7. gearheadmike
    Mar 8, 2012
    8
    ok didn't know if they had one for 4cyl. Now they don't make a a after market module for a hall-effect ignition?
    Or could i get a vacuum advance dist from a older vw engine with points then add a electronic ignition kit?
  8. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
    Why VW? You don't have a VW engine in your car, it's a US engine, designed and built.
  9. gearheadmike
    Mar 8, 2012
    8
    i read in that some people fitted a older vw dist (bosch 009 i think) with points and a vac adv. to get away from the
    electric spark control.
  10. ImperialCrown
    18,344
    2,704
    1981 should have the carburetor with the Electronic Fuel Metering solenoid (green and tan wires). The mixture is controlled by the oxygen sensor in the exhaust.
    I strongly suggest that you do not remove, defeat or tamper with this system. If the car runs bad, properly diagnose and repair what is wrong with it.
  11. LouJC
    LouJC Active Member
    Oct 7, 2014
    522
    371
    I think the early years of the Omni/Horizon did use VW Rabbit engines till ChryCo could make enough of their new 4 cyl engines. A good friend had an '81 Omni 024 and it definitely had a VW engine.
  12. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
    Yes, 2.2L was optional in 1981, and by 1984, the VW engine was gone.
