NewsNew Pacifica trim to hit sweet spot? • Does the Demon stop faster than the Camaro ZL1? • More Waymo Pacificas; public to test
New clutch
Discussion in 'Technical Support & Help' started by jondickson, Apr 20, 2017 at 9:33 AM.
  1. jondickson
    jondickson Member
    21
    71 satellite. 3 speed slant Six. Just put a new clutch and pressure plate on my Plymouth. The clutch isn't engaging and letting me put it in gear. I've adjusted it completely in and out. Still not enough. Do I need to do something different with the linkages?
  2. 68RT
    68RT Active Member
    363
    Describe how pedal movement feels. Is there a slight bit of free movement before you feel the spring pressure of the clutch pressure plate?
  3. jondickson
    jondickson Member
    21
    It feels honestly like it did prior. Maybe a little more smoother. But when you go to put in gear it grinds.
  4. 68RT
    68RT Active Member
    363
    Simply means disc is not fully releasing. Normally caused by disc in backwards, linkage incorrect, or disc warped. Have seen fingers not correct but possible.
  5. jondickson
    jondickson Member
    21
    The clutch disc could only go one way when installed. The other way pushed it away from the crank. How do I check linkages? What next.
  6. jondickson
    jondickson Member
    21
    I'm hoping it's just linkages. Everything else seemed correct when installed.
  7. jondickson
    jondickson Member
    21
    Ok. This might help. I can put it in gear while not running. Push the car and it won't move. I can push in on clutch and it can be pushed easily. This grinding is only when motor is runnin
  8. Bob Lincoln
    Bob Lincoln "CHECK FAULT CODES" Level 2 Supporter
    2,577
    Throwout bearing damaged or incorrectly installed?
  9. 68RT
    68RT Active Member
    363
    Typical action of a clutch not releasing. Can you see in where the throw out touches the pressure plate? Should touch all fingers at the same time.
  10. jondickson
    jondickson Member
    21
    I installed it exactly the way the other was. there was really only one way to install it so the clamps went in behind the fork. Does this mean I will have to remove the transmission?
  11. jondickson
    jondickson Member
    21
    I
    I haven't looked at the fingers closely yet. Sure hope I don't have to remove the trans. Thought I had it all perfect
  12. jondickson
    jondickson Member
    21
    Picture of the old one. I installed new one same way
  13. 68RT
    68RT Active Member
    363
    Only shows throw out bearing. Not plate.
  14. jondickson
    jondickson Member
    21
    I'll try to get some pics this afternoon of it underneath. Post them later.
  15. dana44
    dana44 Well-Known Member Ad-Free Member
    1,329
    How does the pedal feel? Where is the pedal location when you start feeling pressure, and where is the pedal location when the car is in gear and letting it out starts to move the car? This adjustment should be about one third the distance from the floor, if near or above halfway the clutch isn't adjusted tight enough, too much play, so the clutch isn't disengaging enough. Check through the linkage for slop and worn bushings and metal on metal wear. I'm thinking everything was installed correctly, just not adjusted properly to disengage the clutch. Heck, the clutch fork itself may be worn, so check the pivot on that.
    jondickson likes this.
