NewsWhat’s special about the Demon? • Demon has a freakin’ TransBrake • Pritchett’s Challenger Drag Pak isn’t a Demon
New JL Wrangler pics - now wearing less camoflage
Discussion in 'Mopar News and Rumors' started by corpcow, Feb 24, 2017.
  1. Ruptured Duck
    Ruptured Duck Member Level 2 Supporter
    732
  2. Mike V.
    Mike V. Moderator
    14,959
    Typical Allpar, can't see the forrest for the trees.
    Mike
    dmcdonald and Ruptured Duck like this.
  3. D0C
    D0C Active Member
    38
    Maybe it is because they are sitting too low and need bigger wheels :p
    UN4GTBL, crmarczak, wtxiceman and 2 others like this.
  4. Mike V.
    Mike V. Moderator
    14,959
    Holla, 32" blades on the JK.
    [​IMG]
    Or 34's FTW
    [​IMG]
    Mike
  5. Ruptured Duck
    732
    :confused:o_O:rolleyes:
  6. Mike V.
    Mike V. Moderator
    14,959
    See edit
    Mike
    Ruptured Duck likes this.
  7. AmpLighter
    AmpLighter Member
    18
    ..and now we enter the "other" end of the wheel spectrum.. Where as the 16'' may look silly on a JK sport and the JKU sport, anything above 22'' is down right stupid and would never see a rocky, mud covered trail.
    In my opinion, there should be more tire than rim, not the other way around.. 17'', 18'' & 19'' are all good for road use, but 15'', 16'' & maybe 17'' should see the larger tires for off road.
  8. wtxiceman
    wtxiceman Member Level III Supporter
    179
    Perfect, available on the Rubicon?
    UN4GTBL, suzq044 and Mike V. like this.
  9. y2kyamr6
    y2kyamr6 Member
    29
    Factory option right??
    Mike V. and wtxiceman like this.
  10. corpcow
    corpcow Member
    66
    Willys lettering just seems cooler than Jeep on the grille for some reason.
    Mike V. and Dave Z like this.
  11. link3721
    link3721 Needs More Jeep Level 2 Supporter
    380
    I just threw up in my mouth a little...
    Bajanbuoy, xjgary and Mike V. like this.
  12. aldo90731
    aldo90731 Active Member Level III Supporter
    5,741
    Mike V. likes this.
  13. aldo90731
    5,741
    Geez, I can't unsee that now...
    Mike V., wtxiceman and AmpLighter like this.
  14. Ruptured Duck
    732
    Honestly it comes down to how you use the Jeep off-road. A 37" tire on a 20" rim almost has the same type of sidewall movement (flex) as a 33" on a 15" rim (used to make a point, no need for hard numbers). 15" rims on a CJ with 33" tires was the hot ticket for years. Then 35" were more common and is what is used on JK's for the most part. Most JK's come from the factory with 17" now. I would argue the days of 15" - and 16" rims are behind us for now. 35" - 37" on a 17" rim is the new norm. 18" and 20" follow after that.
    Here are 17" rims with 37" tires
    Same Jeep 20" rims and 37" tires
    Bionicrooster likes this.
  15. Hemidakota
    Hemidakota Member
    68
