Odd oil filter positions !
Discussion in 'Rumors and Speculation' started by DC-93, Aug 1, 2017.
  1. Bob Lincoln
    Jul 10, 2002
    29,875
    3,255
    The location, or the oil? Filters are supposed to remain full after the crankcase is drained.
    valiant67 likes this.
  2. Bob Lincoln
    Jul 10, 2002
    29,875
    3,255
    Regardless of the final orientation, I pour over 1/2 quart into a new filter while the oil pan is draining, and it all gets absorbed by the paper element. I then add as much as I can without it spilling as I screw it in place.
    DC-93 likes this.
  3. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,593
    357
    My uncle had a 6-71 in his fishing boat, Never left him at the dock in 40 years.
  4. mopar22
    mopar22 Well-Known Member
    Sep 22, 2010
    1,182
    387
    If it done correctly and on top f the engine it will be sitting higher then the pan. There will be a little bit but not a ton
  5. Bob Lincoln
    Jul 10, 2002
    29,875
    3,255
    If what is done correctly? The oil filter is higher than the pan. On my car it's horizontal. It gushes when I replace it, as it's still full.
  6. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    888
    293
    K cars with the 2.2/2.5 were the easyiest.
    vipergg likes this.
  7. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,604
    335
    Oil filter thoughts:
    If discussing filters that face up; i.e. the 3.6L Pentastar, etc. , I vastly prefer the canister style (with the cartridge, O ring, etc) since the oil tends to drain back into the engine once the cap has been removed.
    Filters that face down or close to it i.e. the old 318-360 motors, I'll take a full flow spin on.
  8. Lorena
    Lorena Active Member
    Apr 24, 2015
    85
    102
    Top down oil change?
    Minivans take an extra step regardless with the filter due to the air intake [~1 min?]... however on another such as the Dodge Avenger/200: the top down oil change can literally take a matter of minutes.
    1. Take 15/16th/22mm socket on the oil cap,
    2. swap filter (lube new o-ring!)/replace cap
    3. extract oil
    4. fill oil
    check for leaks
    I see this as an improvement.
    wtxiceman and DC-93 like this.
  9. Meester Beeg
    Meester Beeg Active Member
    Sep 10, 2016
    140
    45
    Pikers, all of ya....
    The oil filter on my m/c is INSIDE the engine. Remove 14 Allen head bolts and drop the pan and sump spacer-two gaskets. Place pan on ground and spin off oil filter.
    DC-93 likes this.
  10. DC-93
    DC-93 Active Member
    May 1, 2014
    1,626
    802
    I agree on the Pentastar engines. Don't forget to torque the filter housing to 25Nm. That's important - to loose and you get potential leaks. Too tight and it can crack the plastic housing at install, or the next time you attempt to remove it.
    Here's a photo of an old 1960's era Slant 6. When you unscrew the white oil filter, you have to lift it up to clear the stand pipe and a quart of oil dumps out of the bottom, hopefully most falling into the well placed drain pan. ;)
    Citation84 and Lorena like this.
  11. 71Charger_fan
    71Charger_fan Active Member
    Aug 1, 2014
    267
    172
    '82 Camaro 2.8 liter 4-speed. Filter was a PITA between the engine block and the clutch linkage.
  12. mopar22
    Sep 22, 2010
    1,182
    387
    I'm not too sure but on the new 2.0t it's on the left hand side. You just replace the inverted filter and have the usual German oil filter housing. Many people on the gti forums have changed the filter before changing the oil.
  13. vipergg
    vipergg Well-Known Member
    Apr 8, 2002
    2,372
    519
    Definetly , those were simple to change but could be a litlle messy but easy to clean up.
  14. Lorena
    Apr 24, 2015
    85
    102
    Sweet slant 6 :) the positioning sounds almost as "fun" as transverse mounted ford modular engine filters.
    Oops, yeah - forgot the torque to spec part :) I've gotten used to the pressure that I just do the last turn or turn with the torque wrench. Sometimes I am right on the money without adjustments! :p
    I always tell ladies to get their guys torque wrenches and such. Getting 30 thousand random sockets over a lifetime is great for me for their yard sale, but I know I have way too many "useless" sizes. Everyone should have a series of torque wrenches. Bare minimum for anyone should be one large enough for lug nuts. If I have to lend a hand (small hands + tech know-how = volunteered).
    I'm a happy gal even when translating boyfriend/girlfriend :confused: garage talk until you hand me [​IMG]
    instead of: [​IMG]
    I detest "ezy outs" or whatever they are. Stripper allen caliper brake bolts are annoying enough when the outside is as smooth as the inside... without gaining a snapped off rod in it lol. :D
    DC-93 likes this.
  15. 1932highboy
    1932highboy Member
    Aug 6, 2017
    2
    1
    Don't you guys drain the filter before removing? I do, punch a hole in it and it drains the oil. No mess ,no fuss.
  16. mopar22
    Sep 22, 2010
    1,182
    387
    Gotta be careful just in case it doesn't want to come off
    ScramFan likes this.
  17. 1932highboy
    1932highboy Member
    Aug 6, 2017
    2
    1
    I always break it loose first, then punch hole.
    codypet likes this.
  18. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,593
    357
    Semi-vertical orientation of the oil filter on the slant six is the reason why the Ph8A has an anti-drainback valve.
    Dave Z and pt006 like this.
  19. pt006
    pt006 Active Member
    Dec 24, 2014
    1,284
    491
    Agreed. Before they put the anti-drain back valve in, all the oil in the filter would slide out and it was a race to lift out the filter before all the oil drained out. Started in the 80's, I think.
  20. codypet
    codypet Well-Known Member
    Jun 30, 2005
    1,574
    354
    My wife's Subaru has it to the left of the engine starting you in the face next to the battery completely away from the engine with the mouth facing down. Easiest removal ever.
    That 2.6 though. I have it in the minivan and its tucked up against the firewall next to the exhaust manifold and far enough away from the drain plug that you'll likely miss all the oil coming out of the filter. Easiest way I've been able to take it off is to lay behind the passenger wheel with a bunch of socket extensions. To put it back in, I have the lay on top of the car to reach far enough over the engine to put it back in. Its a beast and I feel like there's a crap ton of room in the engine bay of the minivans. I'd hate to think how much engine space is in the K cars.
