Old cars in the snow
Discussion in 'Off Topic But Still Civil' started by voiceofstl, Dec 31, 2017.
  1. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    972
    326
    cars from the 60's and 70's There doesn't seem any rhyme or reason but some cars are good in the snow and other are not.
    I had a 66 coronet and other b bodys and they pretty good in the snow. My 79 Malibu with all season radials was like a hocky puck
    Shane Estabrooks likes this.
  2. CherokeeVision
    Dec 9, 2004
    5,405
    2,080
    My opinion only.
    Vehicle length, width and weight for starters.
    Short and narrow makes it easier to swap ends. Backing up with a short trailer is an example of this. Doesn't take much wheel movement for a short trailer to turn. Makes it trickier than a long trailer.
    Then tire width, contact patch and how much weight is on that contact patch.
    For off roading there are two schools of thought when it comes to tires and snow.
    Often the depth of the snow and the ground surface under the snow is a determining factor.
    Wide tires for flotation on top of the snow or narrow tires to cut through the snow to the surface underneath.
    The wider a tire (larger the contact patch) the less weight per square inch (or however you want to measure it).
    Then there is the tires tread. Does it pack with snow or does it clean easily?
    Are there enough biting edges to the tread?
    Does the tire simply pack up and give up? Kind of like when a tire hydroplanes. Here is where I think too wide of a tire in snow might be bad.
    Not enough weight to push down through the snow.
  3. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,609
    384
    My 73 Dart with studded snow tires did pretty good in the snow. You learned how to start, stop, and turn without the aid of computers, It was actually kind of fun sliding a car through a turn, almost like drifting.
  4. valiant67
    31,963
    11,532
    My best old winter car is the 79 Cordoba I still own. It warmed up faster than any other car I’ve owned. With 3.2 gears in a Sure Grip rear, with real snow tires that car would plow snow.
    Devildodge likes this.
  5. rapidtrans
    rapidtrans Well-Known Member
    Jul 29, 2005
    1,346
    614
    Many variables involved here. The type of snow, tire compound, width, car weight etc. Dad always had two company cars so we never had snow tires through our Michigan winters. Some models like the “E” bodies and Camaros were just too light in the rear and usually had wider tires. More importantly is learning the proper driving style in winter. You learn to “steer with the throttle”, keep your forward momentum etc. My rwd 16 Charger RT gets around in snow ok till the snow is so deep the undercarriage starts scaping snow. The std. Firestones are worse in a summer rain than snow covered roads.
  6. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,824
    470
    I had a 74 Duster with the slant 6 and 3 speed in the floor. It was an awesome snow car.
  7. RalphP
    Aug 26, 2014
    102
    34
    Best snow car I had was a 1967 Mustang. The year we had so much snow I had to dig out so I could open the doors, I could go all around town (slowly, carefully!) and pass police cars and tow trucks off the road ...
    My wife's 1991 Cougar, with the Yokohama 225/65R16s, was just as good a few years back. I've not had to test it since, though.
    RwP
  8. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    12,221
    1,709
    The best RWD snow car I had was a '79 Monza 4 speed manual 2.5L. It was like a tank in snow even in 10"+ snow. Since it sat low it did plow the snow deeper than 6", but she would still go. As long as you knew how to feather the throttle I never had a problem. Good all weather or snow tires makes a big difference.
  9. peterjon1
    peterjon1 Well-Known Member
    Aug 14, 2004
    1,121
    81
    1973 Olds Toronado. I took it for a test drive on a sloppy slushy day, with bald summer tires. It didn't care. I could go through 3 inches of slush on the road without any wavering. The reason for that was readily apparent; weight of over 5000 pounds, mostly on the front end.
  10. peterjon1
    Aug 14, 2004
    1,121
    81
    1973 Olds Toronado. I took it for a test drive on a sloppy slushy day, with bald summer tires. It didn't care. I could go through 3 inches of slush on the road without any wavering. The reason for that was readily apparent; weight of over 5000 pounds, mostly on the front end. Best RWD was 79 Impala wagon with snow on the rear.
  11. voiceofstl
    Jan 15, 2010
    972
    326
    Thats FWD with a big block. that doesn't count.
  12. dana44
    Ad-Free Member
    Jun 17, 2002
    19,343
    1,249
    My 68 Charger and 74 Barracuda were great in the snow. Had a 64 Bel Air that would do 360s out of the blue without rhyme or reason in the snow. Drove a 72 Blazer 4X4 that was pretty scary, too. My old 88 Dakota wasn't very good in the snow, but still better than my non-Mopars.
  13. DC-93
    DC-93 Active Member
    May 1, 2014
    1,650
    814
    In high school, 1972,3,4, my '68 Charger with G-60s all around was ok in the snow!
    Best was a 68 Dart, 225 leaning Tower of Power, 904 trans. Had skinny pizza cutter tires, some early radial, maybe "Trax" (???)
    My 74 Charger SE was ok, in the BIG SNOW of 1978 in MI. (look that one up)
    Never got stuck in any of them.
  14. rapidtrans
    Jul 29, 2005
    1,346
    614
    I was living in Traverse City in ‘78. Both bays froze over out to mission point. I was driving a Volare and a ‘74 Charger that year. Had a pair of Polyglas Gts recapped to snows to get thru that winter!
  15. peterjon1
    Aug 14, 2004
    1,121
    81
    Sorry, Didn't see you specify Rwd only anywhere.
  16. ka9yhd
    ka9yhd Active Member
    Aug 17, 2013
    1,158
    220
    A friend used to own a 67 Plymouth Fury III and his father would always buy a set of the cheapest tires at Sears for the car. These tires were under the load capacity rating for the vehicle and would wear out quickly. Driving the Fury in the winter was like being on ice skates.
    I was telling my friend about experiences of friends with the Uniroyal Tire Paw tires. So my friend grab a set of Tiger Paws from the Caddy dealer where he worked. These tires were pull offs from a Cadillac Brougham, which were new tires.
    My friend was amazed at the traction his 67 Fury had with the Tiger Paws. He could out accelerate the traffic in snow.
  17. Bob Lincoln
    Jul 10, 2002
    29,940
    3,329
    Had a 72 Dart that would sometimes spin its tires in the snow, but found that I could turn around and back up a hill just fine, or go in reverse on the level when I could not go forward.
    chuzz likes this.
  18. chuzz
    Apr 3, 2004
    6,824
    470
    I had a 70 Dart like that when I was in college, Bob. Was yours a Swinger too? I had the typical green with black vinyl top. Slant 6, 904, of course.
  19. voiceofstl
    Jan 15, 2010
    972
    326
    My Dad took me to a large parking lot when I turned 16 to teach me how to drive in snow. Ever since then I would take my RW drive cars to a parking lot and have fun.
  20. Bob Lincoln
    Jul 10, 2002
    29,940
    3,329
    4-dr Custom. Slant-6 and auto.
    chuzz likes this.
