Overflow. Easy way to check
Discussion in 'PT Cruiser' started by Kristy13, Jul 7, 2017.
  1. Kristy13
    Kristy13 New Member
    Apr 6, 2017
    2
    Is there a easier way to check the fluid level
  2. Best Answer:
    Post #7 by AllanC, Jul 10, 2017
  3. ImperialCrown
    18,339
    2,702
    Welcome to Allpar. The 'add' and 'full' marks are easier to see on some years and not others.
    Wiping the outside of the white plastic jug if it is dirty may help the level line show better. Gently rocking the vehicle will make it slosh so that it may yet be easier to see.
    If the inside of the jug is scummy, it can be removed and scrubbed out with warm soap and water.
    You should only have to check the level periodically as some water in the coolant will evaporate over time. It should be a 50/50 mixture.
    If there is a coolant leak somewhere, that will mean that you will have to add coolant more frequently. In that case, it would be good to fix the leak.
  4. Kristy13
    Kristy13 New Member
    Apr 6, 2017
    2
    Thanks I heard you can add a dye to make it easier is that crap
  5. ImperialCrown
    18,339
    2,702
    A dye can be added to trace a leak, but I usually don't find it necessary with coolant.
    If there is a leak, look for a drips on the ground or a trail from the likely suspects: hoses, radiator, water pump, thermostat housing, etc.
    The A/C can drip water (condensate), that's normal.
  6. NEMopar
    NEMopar Active Member
    Oct 22, 2002
    85
    4
    What works for me is to look at the tank from over the right side fender, and drop a fluorescent droplight behind the left (driver's) side of the tank. You'll see it pretty easily, if the tank is reasonably clean.
    djsamuel likes this.
  7. djsamuel
    Sep 10, 2007
    2,690
    436
    This is what I do too.
  8. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    3,163
    420
    This location of the coolant overflow container is very similar to the mounting that my 2003 Neon has. Since it is at the firewall it is difficult to get a good view of the level. As others have mentioned it helps to have a container which has the scum that accumulates on the inside surfaced scrubbed clean. Also I have removed the container and placed a short, thick black magic marker line at the low and high levels. That helps.
    Also when checking the level I take a flashlight, remove the container cap and shine the light directly into the filler tube. That helps to illuminate the inside surface and level and then a slight rocking motion identifies the coolant level.
    ImperialCrown likes this.
  9. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,824
    471
    I did the same thing that AllanC does. It's dang near impossible to clean on of the overflow tanks once it gets funky!
  10. ImperialCrown
    18,339
    2,702
    I like the black magic marker idea.
  11. AllanC
    Jan 6, 2003
    3,163
    420
    Take an old toothbrush that you no longer use. Tape it securely to stiff wire such as coat hanger wire. Use very hot water and detergent and scrub. This will get most of the inside surface except for certain narrow areas.
    chuzz likes this.
  12. chuzz
    Apr 3, 2004
    6,824
    471
    Great idea, Allan. I'll do that the next time I want to clean one. I may be an old dog, but I'm still willing to learn new tricks!
  13. gringo
    gringo Member
    Oct 17, 2015
    3
    Yep, this old dog appreciates that as well.
