AF: P301 2003 GT | Allpar Forums
P301 2003 GT
Discussion in 'PT Cruiser' started by Bill AZ, Sep 9, 2020.
  1. Bill AZ
    Bill AZ Active Member
    Mar 6, 2019
    101
    25
    Once again asking for input for my Grandsons PT. Pulled first plug on the left, totally carboned up. Missing badly, haven't tore into it yet, thinking it might be the coil (after market). Changed coil and wires 2 years ago, turned out to be valve. Retired, no hurry, Grandson likes my Lexus.
  2. Bill AZ
    Mar 6, 2019
    101
    25
    Replaced coil, have the aluminum intake, slides right in.
    06PTElectricBlue likes this.
  3. 06PTElectricBlue
    Apr 2, 2019
    954
    1,080
    And on the Turbo models, you can also change the plugs without having to remove the intake manifold.
    I wish they had designed the N/A like that ;)
  4. chuzz
    chuzz Allpar Legacy
    Apr 3, 2004
    8,028
    1,098
    Did the coil cure the problem, Bill? I'd put a new plug in there too.
  5. Bill AZ
    Mar 6, 2019
    101
    25
    When I bought the PT from my neighbor it had a miss. Changed coil, no help. Had the original coil and put it back in, all is well. After market coil didn't last. I have the aluminum intake and the plugs are easy to change, I did replace them when I bought it, they still look good. Bear Frame replaced two bushings and aligned, runs smooth and true, although after having the trans replaced I think they forgot to tighten a nut and when turning a big snapping noise. Taking it back Monday the 14th where they will correct the problem.
  6. Bill AZ
    Mar 6, 2019
    101
    25
    Yes, it was the original coil as I had been doing "shotgun" repairs with a bad valve when I bought it.
  7. chuzz
    chuzz Allpar Legacy
    Apr 3, 2004
    8,028
    1,098
    You might ask them to check the lower control arm bushings for that noise.
  8. Bill AZ
    Mar 6, 2019
    101
    25
    Bear Frame and another private shop checked everything, all looked good, up up for anything now.
    chuzz likes this.
  9. chuzz
    chuzz Allpar Legacy
    Apr 3, 2004
    8,028
    1,098
    Did they have a reason for the noise you heard?
  10. Bill AZ
    Mar 6, 2019
    101
    25
    It is still in the shop where the trans was changed, a mechanic told me he heard the noise (snapping, clunking) while I was driving it straight, not turning. I'm thinking the trans is gone, I'm not picking it up till it is fixed.
    chuzz likes this.
