Pink eye
Discussion in 'Dodge Dart / Viaggio' started by PCRMike, Aug 15, 2016.
  1. PCRMike
    PCRMike Well-Known Member
    Mar 3, 2010
    1,865
    705
    First issue I have had, but on the way home tonight, my drivers headlight turned pink. Yes, pink. No idea why, but it is absolutely, positively, pink as Polly's panties. Any ideas? I have the Limited, and am not sure if they are HID, or bulbs.
  2. Bob Lincoln
    Jul 10, 2002
    29,868
    3,241
    If they are LED lamps, the green chip(s) failed.
  3. ka9yhd
    ka9yhd Active Member
    Aug 17, 2013
    1,153
    220
    I just had a look at the Dodge web site and at the Dart. All I see offered is the Halogen Projector lamps.
  4. valiant67
    31,636
    10,867
    Xenon will turn pink as the bulb fails.
    I m fairly certain HID (Xenon) lights are available on the Dart though LEDs aren't.
  5. ka9yhd
    Aug 17, 2013
    1,153
    220
    Interesting. I have seen replacement HID's pink. HID lamps are nothing more then an arc lamp similar to the Mercury Vapor or Metal Halide street lamps and I have seen them get dim as they age. Usually when I see one light up with either a pinkish or greenish glow there is usually impurities in the gas.
  6. PCRMike
    Mar 3, 2010
    1,865
    705
    Pink before it fails per the dealer. I will get one from my daughter at O'Reilly Auto. Even with her discount, 106 bucks! At least it is an easy swap. Unlike a Toyota or Honda.
  7. PCRMike
    Mar 3, 2010
    1,865
    705
    Bought OEM bulbs from wish.com for 18 bucks a pair. D3S bulbs.
  8. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,198
    14,698
    $106 isn't bad when you consider how much you saved by getting 'em for a Dart instead of, say, a 300!
    $18 is a steal.
    Would love to retrofit HIDs but don't think that works.
  9. valiant67
    31,636
    10,867
    You often can for OEM HIDs - but some tricks are involved. If you don't the HIDs will flicker.
