plug removal
Discussion in 'A Body: Duster, Valiant, Dart, etc' started by jmas11, Jun 23, 2017.
  1. jmas11
    jmas11 New Member
    Jun 5, 2017
    10
    1
    Without pulling the eng., anyone have a suggestion on how to get #'s 5 & 7 plugs out of a 340 block with hedman, headers in a '75 Duster. They were installed before the block & headers were installed..... Any special tool or tricks would be appreciated!
  2. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,514
    240
  3. Bob Lincoln
    Jul 10, 2002
    29,868
    3,241
    Or undo the motor mounts and jack it up for clearance.
  4. jmas11
    jmas11 New Member
    Jun 5, 2017
    10
    1
    Universal won,t clear the header. I can put the socket (by itself) on the plug with some maneuvering, but clearances stop the extensions or universal from clearing and a 3/4" open end or box end on the socket has same results.......
    You would think that There must be some obscure tool for this problem, as I am sure this problem has been around for a long time!
    I will keep looking to avoid the alternative.
  5. geraldg
    Ad-Free Member
    Nov 28, 2002
    3,825
    746
    I think if you could take a picture it would help with ideas.
  6. geraldg
    Ad-Free Member
    Nov 28, 2002
    3,825
    746
    Have you tried going underneath the car and also I had a car where I had to go thru the wheel well after taking tire off.
  7. jmas11
    jmas11 New Member
    Jun 5, 2017
    10
    1
    wheel well is closed off and underneath is too close to maneuver.
    I'll try the Westward wrench.....and keep looking around.
    Thanx
  8. geraldg
    Ad-Free Member
    Nov 28, 2002
    3,825
    746
    Try going to forabodiesonly website, I am sure somebody their had that problem and could help you.
    DC-93 likes this.
  9. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,510
    438
    Spark plug socket with a hex on the top and a combination wrench. Please do it when headers are cool.
    pt006 likes this.
  10. pt006
    pt006 Active Member
    Dec 24, 2014
    1,281
    490
    SK brand made a 3/8" drive spark plug socket with a hex head on top. About the shortest I know of.
    cavemanmoron likes this.
