AF: Power steering conversion kits for 1957, 1958, 1959, 1960, and 1961 Plymouth and Dodge | Allpar Forums
Discussion in 'Parts for sale or swap' started by finishfloyd, Nov 5, 2019.
  1. finishfloyd
    finishfloyd Member
    Oct 9, 2018
    7
    3
    I have a business (YouTurn Power Steering conversions) that builds and sells power steering kits for 1957 thru 1961 Plymouth and Dodge. We understand that keeping your car original is very important, but there may come a time when, trying to find an old replacement or N.O.S. gear or pump and hope to have it repaired, becomes a daunting or impossible task, so this is why we developed these conversion kits. If you have a worn out system and are looking for a complete or partial replacement, we have you covered. 1957, 1958, 1959,1960, and 1961 Plymouth with the following engines; 277,301,318,350 C.I.D. and 1957,1958,1959,1960,1961 Dodge w/ 315,318,325,326, C.I.D. engines. This conversion kit includes a heavy duty power steering gear, Pittman arm (if needed), gear mounting adapter plate, power steering pump, pump bracket, pump pulley, pump cap, 2 groove water pump pulley (if needed), hoses and fittings set, universal joint, column extension adapter, column floor bracket and rubber boot, shaft extension (if needed), hardware and instructions.
    Contact information:
    Floyd Richard
    YouTurn Power Steering Conversions LLC
    Email - [email protected]
    Ph. (409) 789-4064
    [​IMG]
  2. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,834
    471
    That conversion; would it also work on same era Chryslers as well as 1962-64 C bodies? Why I ask is that may broaden your potential customer base. :)
