Power Steering Filter
Discussion in 'Dodge Journey' started by Elliot, May 5, 2014.
  1. Elliot
    Elliot New Member
    Nov 26, 2012
    21
    2009 Journey SE. Anyone know if the power steering system has a filter/screen and where. I've seen that some Caravans have a screen in the fluid reservoir that gets dirty and causes pump noise. With 90k mine has developed a little whine, wondering if the Journey uses a similar setup.
    18,231
    2,659
    I believe that there if a non-serviceable mesh screen in the reservoir. Use ATF+4 as a fluid. A fluid flush/change sometimes helps with P/S noise issues (if it has never been done before). If the ATF+4 is darkened, change it.
    If the screen is restricted with debris, replace the reservoir.
  3. Powdered Toast Man
    Powdered Toast Man Move along, nothing to see here
    Apr 7, 2003
    1,929
    981
    Typically, Journey power steering lines explode long before the fluid is an issue so you get new fluid when they fix it.
