AF: problem adding fuel. | Allpar Forums
Discussion in 'Cherokee, Liberty, Nitro' started by Richard in Idaho, Nov 7, 2019.
  1. Richard in Idaho
    Richard in Idaho Active Member
    Jan 12, 2004
    99
    6
    This has happened at two stations. The nozzle shuts off as soon as you pull the handle. The tank is nearly empty. It seem that the fuel stays the the filler tube shuts off the pump and then very slowly goes into the tank. Never had as problem until yesterday..This in on a 2014 Cherokee V6.
    Thanks
    Richard
  2. Bob Lincoln
    Jul 10, 2002
    31,496
    4,663
    In my experience, this happens because of the pump, not the car. I have had to squeeze the handle just enough to get gas to flow in the smallest amount, then very slowly increase the flow after about 1/2 gallon has been pumped.
    Shane Estabrooks likes this.
  3. valiant67
    valiant67 ...
    35,497
    17,347
    I've had a couple of cars that had this issue and it happened at different gas stations. Since both were spare vehicles, I just got used to filling them more slowly as they could never accept more than 1/2 the pump's flow without shutting off the pump..
    I'd try another station or two just to make sure it isn't a pump problem.
  4. ImperialCrown
    ImperialCrown Moderator
    20,535
    3,867
    The gas tank does need to vent into the charcoal canister while refueling. The system is called ORVR for On-board Refueling Vapor Recovery. The tank needs to breathe.
    If there is a restriction, rollover valve malfunction or if the canister has flooded, it can cause your symptoms. Rule out a pump nozzle issue first.
    [​IMG]
  5. 1999 White C5 Coupe
    1999 White C5 Coupe Well-Known Member
    Jul 11, 2006
    428
    256
    Any update?
  6. Shane Estabrooks
    Dec 9, 2014
    758
    532
    If a nozzle at a fuel station is not matched to the pressures from the pump .. then this could happen. Experienced this in the diesel world so just assuming that It could happen in the gas world.
  7. Richard in Idaho
    Jan 12, 2004
    99
    6
    They replaced the Canister - Vapor and the Tube - Fuel Filler. Did NOT help at all. They have ordered a Gas Tank. To see if that helps. They seems have no idea how to fixed it.
    Glad that I have Mopar Vehicle Protection. Let FCA pay for all of this.
