AF: Quick Drive: Canadian 2019 Ram 1500 Sport with 2-Inch Mopar Lift: | Allpar Forums
Discussion in 'Mopar / FCA News' started by redriderbob, Oct 5, 2018.
  1. redriderbob
    redriderbob Mopar Guru!
    Supporter
    Feb 22, 2004
    12,765
    23,203
    5thGenRams.com Gets Behind The Wheel Of The Canada-Only Sport...
    [​IMG]
    Thanks to our friends at Abbotsford Chrysler, 5thGenRams.com got some time behind the wheel of a Canadian-only 2019 Ram 1500 Sport Crew Cab 4×4. Not only is this the Canadian-only Ram 1500 Sport model, but it is equipped with a 2-inch lift by Mopar.
    For more pictures and the complete article, click the link below...
    Quick Drive: 2019 Ram 1500 Sport With Mopar 2 Inch Lift - 5th Gen Rams (at https://5thgenrams.com/quick-drive-2019-ram-sport-with-mopar-2-inch-lift/ )
    Hemidakota and wilbur like this.
  2. GasAxe
    GasAxe Well-Known Member
    May 12, 2008
    6,726
    10,230
    Sweet truck.:) The tires equipped equate to a 33.5" tall tire, so if you move up to the max recommended 35", there probably isn't enough of an increase on the sidewall to help smooth it out much more. Gosh I hate rims that large. 18" wheels (or smaller!) would look so much better and give enough room for more sidewall flex.
    hotmach likes this.
  3. BobbiBigWheels
    BobbiBigWheels The "Front-Line" Perspective
    Jun 2, 2016
    3,245
    4,876
    Nice truck. Only a really bad [I should have my mouth washed out with soap for using such terms] dealership would do such a phenomenal kit...
    wtxiceman and Devildodge like this.
  4. Max Wedge
    Max Wedge Well-Known Member
    Oct 18, 2013
    975
    476
    Those 2 inches dont even look visable.
    Hemidakota likes this.
  5. wilbur
    wilbur Well-Known Member
    Feb 19, 2014
    1,193
    1,231
    Would be nice to compare it with a normal DS for comparison.
    It also has larger tires that are probably taking up some wheel well room.
    I know, it's hard to tell the difference in my truck with the variable rate springs until I park it next to a regular truck.
    Wil
  6. mopar22
    mopar22 Well-Known Member
    Sep 22, 2010
    2,806
    2,171
    This should put it on the same level as a regular ds. I was comparing the two beside each other back when and it looked like the dt was a little bit shorter
  7. Max Wedge
    Oct 18, 2013
    975
    476
    In many photos it looks smaller in general. Might just be me though.
  8. redriderbob
    Supporter
    Feb 22, 2004
    12,765
    23,203
    GasAxe, tlc and ScramFan like this.
  9. mopar22
    Sep 22, 2010
    2,806
    2,171
    It looks lighter but bigger depending on the angle if that makes sense. When beside each other though you can tell it sits just a little bit lower.
