Radiator Support Replacement Question
Discussion in '200, Avenger/Sebring, Cirrus/Stratus/Breeze' started by captn, Jul 11, 2017.
  1. captn
    captn Active Member
    Jan 10, 2003
    124
    8
  2. captn
    captn Active Member
    Jan 10, 2003
    124
    8
    Do I have to remove the radiator and condenser to replace the radiator support assembly?
  3. Crawdaddy
    Crawdaddy Member
    Feb 3, 2017
    85
    36
    The radiator and condenser are moved rearward (towards engine) for removal from car. So they will not need to be removed from car to replace the radiator support as the support comes forward for removal.
  4. captn
    captn Active Member
    Jan 10, 2003
    124
    8
    Thank you Crawdaddy, that's what I had hoped.
    I'm getting an up and down movement by grasping the front grille and lightly lifting and there is a larger than normal gap between the hood and the bumper cover as it's tending to hang down. This puts strain on the side retainers just behind the head lights that holds the bumper cover in place.
    I notice the Energy Absorber is not installed and I assume it's postioned in front of the metal bumper under the grille assy.
    A quick question please, does the Energy Absorber hold the bumper cover in place? I am unable to see where the Absorber is fastened to either the bumper or the bumper cover.
    Anybody working in a collision shop who has worked on Chrysler 200's I'm sure can answer this, please.
    Many thanks for any assistance.
  5. captn
    captn Active Member
    Jan 10, 2003
    124
    8
    Yes, the Energy Absorber slides into two pillars on the bumper cover behind where the license plate would be and then sits on the metal bumper which totally rigidly supports the front part of the bumper cover and grille assembly. No more movement of the cover and the side retainers stay tightly together. Installed in less that an hour.
    Crawdaddy likes this.
