AF: Radio ID/questions | Allpar Forums
Radio ID/questions
Discussion in 'EEK! - Every Extended-K Car' started by iowa-k, Feb 16, 2020.
  1. iowa-k
    iowa-k Member
    May 13, 2018
    61
    6
    Picked this up to put in my ‘82 LeBaron with the adapter that I bought a while back. Any idea from what year it is from? Also found it odd that it says “MOPAR” on the front instead of a Pentastar. What would the “recall” button do with an analog dial? Typed in the numbers in google and not much information coming up. Any opinions on these radios? Better than the half working "Quartz Lock" that is in there now?
  2. rapidtrans
    rapidtrans Well-Known Member
    Jul 29, 2005
    1,708
    966
    Looks like a dealer install or upgrade radio. I believe the factory radios were Mitsubishi Electronics units.
    Recall button is probably some function for setting the clock.
    If it fits and works gotta be better than trying to fix the original.
  3. valiant67
    valiant67 ...
    36,288
    18,741
    That is likely a dealer installed radio. Since it has the newer connectors on the back, it was designed for 1984 and newer cars.
  4. ImperialCrown
    ImperialCrown Moderator
    21,011
    4,223
  5. Mister Audiovox
    Mister Audiovox New Member
    Mar 25, 2020
    3
    1
    That is a factory Mopar radio with a digital frequency/clock display to the left of the analog dial. The recall button toggles between frequency and clock display.
  6. valiant67
    valiant67 ...
    36,288
    18,741
    No, it is not a factory radio. It’s a Mopar unit for dealers to install to upgrade. The factory radios never said Mopar on them.
