Ram HD 6.4
Discussion in 'Ram, pickups, commercial trucks' started by Shane Estabrooks, Mar 2, 2015.
  1. Shane Estabrooks
    Dec 9, 2014
    545
    348
    Well that's twice for my tranny, this time they replaced it with a new one. I did some digging into this issue and found out that it is all in the programming. What was basically happening was between 70 and 90 Km the tranny line pressure was bouncing between high and low line pressure causing the tranny to destroy the clutch pack in the higher gears (4-5-6). I spend a lot of time at that speed range on the crappy roads we have, so the slowing down and speeding up for rough spots was not helping the issue. Asked them to see if the factory re-flashes would fix this... time will tell. Looks like an after market re-programmer is in order... any thoughts on this?
  2. Dragn142298
    Dragn142298 Member
    Aug 16, 2017
    1
  3. Shane Estabrooks
    Dec 9, 2014
    545
    348
    Where did you get your fender flares? I have been looking online, but can not find any that the front set goes to the bumper like yours.[/QUOTE]
    Had them installed when I bought the truck.. I'm sure they are bushwacker.. couldn't get any without the fake bolts for the coverage needed..
  4. wtxiceman
    wtxiceman Well-Known Member
    Aug 30, 2009
    654
    563
    How is the tranny??
    66rfe?
  5. Shane Estabrooks
    Dec 9, 2014
    545
    348
    Yes it is the 66rfe and so far so good. I can feel the shifts more now but not used to feeling the down shifts after letting off the accelerater. Have brought it back for follow up and they say it's all good.
    somber and wtxiceman like this.
  6. Shane Estabrooks
    Dec 9, 2014
    545
    348
    2017-09-05 12.14.25.jpg If you want to clean out the rads well ... this is the best way. Even though I took the bumper off to repair it and the off-road lights, 4 bolts latter and grille off to expose rads for the best clean they ever had.
    Had a dent in the bumper from a tree stump and the wiring to the LED lights was damaged but if you look close one would say where is the fender skirt... well had to cut them off a bit because they came loose while out bush whacking and the tires chewed them. All is good and put back together like as if nothing happened(work completed before the wife came home...lol)
    somber and Devildodge like this.
