Ram ProMaster Vans Recalled to Fix Airbag Problems
Discussion in 'Mopar News' started by Hemidakota, Dec 6, 2017 at 8:04 AM.
  1. Hemidakota
    Hemidakota Active Member
    Jan 24, 2017
    568
    343
    December 5, 2017 — Fiat Chrysler (FCA US) is recalling more than 3,500 model year 2018 Ram ProMaster vans with side airbags that may not deploy correctly in a side-impact crash.
    FCA found a ProMaster van with a front door impact pressure sensor that had a fractured housing, so engineers opened an investigation and found problems with the installation of the sensor.
    Chrysler says the rivet expands within the plastic attachment of the sensor and causes the sensor housing to break.
    Engineers changed the rivets used to fasten the sensors and repaired 1,349 vans still in Chrysler's possession. The automaker determined the problem can be completely random and unpredictable and all 2018 ProMaster vans made before August 23, 2017, could be affected.
    The recalled vans were built between July 24 and August 23, 2017.
    MORE AT LINK: Ram ProMaster Vans Recalled to Fix Airbag Problems (at https://www.carcomplaints.com/news/2017/ram-promaster-vans-recalled-airbag-problems.shtml )
  2. DAGAR
    DAGAR Active Member
    Sep 21, 2014
    1,344
    1,896
    I wonder if the vans Chrysler fixed are the ones that caused a 45% reduction in Promaster sales for the month. If so, I suspect December to show a nice jump.
