Replacing radiator- '82 NY'er 318
Discussion in 'F-J-M: Volare, Diplomat, etc, 1977-89' started by goair99, Dec 24, 2017.
  1. goair99
    goair99 Active Member
    Nov 9, 2013
    268
    45
    Is replacing the radiator on my '82 NY'er pretty straight forward? Anything I should know before I dive into this project? There looks to be plenty of room...
  2. valiant67
    31,980
    11,552
    Not hard to do. You’ll probably lose a little transmission fluid, so be ready for that. You may want some ATF safe hose and just replace the rubber hose (and clamps) between the metal line and the radiator. It may be hard from age.
  3. goair99
    Nov 9, 2013
    268
    45
    OK , will do. Is there any burping procedure with the 318?
  4. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,559
    249
    Not a difficult job, but you might first want to take the time to flush out the system, including the heater core and removing the block plugs. You might also want to replace the top and bottom hoses, and the heater hoses.
  5. goair99
    Nov 9, 2013
    268
    45
    Yes, I will thanks. I noticed that the bypass hose seems quite larger than on my '89 5th. Unless it's swollen???
  6. goair99
    Nov 9, 2013
    268
    45
  7. valiant67
    31,980
    11,552
    Should be he same bypass hose, 82 and 89.
    I've never had to do anything special for a 318. Fill it up, run without the cap until the thermostat opens, refill. Run the car and check it every day for a couple of days, refilling as necessary (but seldom is there a problem).
  8. goair99
    Nov 9, 2013
    268
    45
    Alright, Thanks to all!
    BTW: I just bought my '82 NY'er. She has 84K and runs 10 times better than my '89 5th with 40K on her. She is Morocco Red with matching top, and in incredible shape for 35 yrs. old. I will post pics tomorrow!
  9. valiant67
    31,980
    11,552
    Sounds a lot like the 82 I once had.
  10. Scrounge
    Apr 30, 2009
    1,559
    249
    Your bypass hose is probably swollen, so you might want to replace it, too.
  11. goair99
    Nov 9, 2013
    268
    45
    Yes I will, already placed my order with RockAuto. Thanks
  12. goair99
    Nov 9, 2013
    268
    45
    Everything is done and replaced, Thanks! The Spectra-Premium radiator didn't exactly match all the mounting holes, but 3 out of 4. Bypass hose was swollen like a giant sausage! Also replaced tranny hoses with new clamps.
  13. Scrounge
    Apr 30, 2009
    1,559
    249
    Good to read it, and I hope it gives you years of trouble-free performance. You might check the clamps every few weeks, and tighten them if needed.
