Rocker Arm Dilemma
Discussion in 'Performance' started by renardk764, Dec 22, 2014.
  1. Locomotion
    Locomotion Active Member
    Mar 11, 2003
    266
    3
    I've only messed with shaft rockers, but this will apply as well.
    Is there enough rocker-to-retainer clearance when you shim the rockers up to get them properly located on the stem?
    Sorry if it's a repeat, but I believe you'll need longer pushrods and only a thread or two should be showing when properly adjusted.
  2. renardk764
    renardk764 New Member
    Oct 12, 2012
    10
    1
    Everything's properly located on the stem. Measurements were taken and appropriate length pushrods were installed. I am bit worried about the rocker to retainer clearance, though. Seems a bit close for my preference given heat expansion, yet I've been unable to identify any wear patterns after rotating it several times.
