Shorted something?
Discussion in 'PT Cruiser' started by Remote95, May 27, 2017.
  1. Remote95
    Remote95 New Member
    May 27, 2017
    4
    unhooked safety chain from trailer but chain caught pigtail when I pulled away and ripped two of the 4 pigtail wires apart. Immediately repaired w/splice and electrical tape. Have lost on car Headlights, tail lights. Have checked fuses under hood and inside car but find none shorted. Any ideas. all help appreciated?
    18,344
    2,704
    Welcome to Allpar. What year? If it has a TIPM (2006+), the internal short-circuit protection may have tripped and needs to be reset. You can try a battery disconnect/reconnect or address the TIPM with a scan tool?
    It could also be at a weak spot like switch contacts or wiring connector has opened? Find out where the power stops and that should be where the problem is.
    Is there power getting to those fuses that are OK and are they labelled that they are specifically for the lighting circuits?
  3. Remote95
    Remote95 New Member
    May 27, 2017
    4
    It is a 2002 pt.
  4. pt006
    pt006 Active Member
    Dec 24, 2014
    1,291
    498
    The early PT's [2001 to 2005] had issues with the multi-function switch. The one on the steering column. And the interior fuse block itself had overheating problems. A test light or volt meter and a wiring diagram would help.
  5. ImperialCrown
    18,344
    2,704
  6. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,824
    471
    Which side of the car did the wiring get pulled loose from? Pull the battery tray and check the wiring under it. You may have to pull the driver side head light to get a good look at that area too. There's a pretty good bit of wiring under the battery tray.
  7. Remote95
    Remote95 New Member
    May 27, 2017
    4
    The wiring was the trailer connect wire or {pigtail wire} outside the car and at the rear. I pulled a code this morning and it shows a code 17, Loss of ignition-Run only. ? Dont know what that means.
