Socket Size
Discussion in 'Repairs, Maintenance, Help' started by slim slow slider, Dec 19, 2017.
  1. slim slow slider
    May 19, 2012
    269
    15
    Need to buy an oil pressure sender switch socket to remove the sender from my 89 Caravan w/ 2.5 engine. There are two size sockets available. One is 1 1/16; the other is 1 3/16.
    Anyone know which one to use?
    Thanks for the help!
    Merry Christmas!
  2. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,527
    445
    Depends on who supplied your sender. Can be either.
  3. slim slow slider
    May 19, 2012
    269
    15
    How about Standard Motors Products. Local parts stores are clueless!!
  4. ImperialCrown
    18,340
    2,703
    I have found that the OEM switch socket is 1 1/16".
  5. slim slow slider
    May 19, 2012
    269
    15
    Thanks so much! I had a deep socket, but have not been able to find it. This saves a LOT of time. Thanks, IC!!
  6. slim slow slider
    May 19, 2012
    269
    15
    Well, I have purchased a 1 1/16 and 1 3/16 inch socket (s) and none of them work! Not deep enough. Using the Standard oil pressure switch. Anyone use the correct socket for removing the switch? Lisle and others make one. But it's pricey! Cannot remember what I paid for the one I can't find! Can't remember the brand or where I bought it. HELP Appreciated.
    Happy 2018!
  7. valiant67
    31,980
    11,550
    As i recall, the switch is designed in a way that a normal socket does not fit it. I believe you need the oil sender socket.
  8. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
    it's on the front of the block, accessible, so I used a large crescent wrench. Worked fine.
    Doug D and valiant67 like this.
  9. valiant67
    31,980
    11,550
    I agree, a crescent wrench works because of the flat spots on the sender, but a regular socket may not because the corners don’t make a perfect hexagon.
  10. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,824
    471
    I've used a pair of channel lock pliers from time to time over the past 45 years of tinkering with cars.
  11. chargermike
    chargermike Active Member
    Apr 3, 2005
    146
    14
    Go to the parts store. Ask for the sending unit. Then find a socket that fits the new one. If yours is leaking then you need a switch anyways.
  12. 68RT
    Aug 8, 2003
    5,527
    445
    Works if you get a six point socket. Hard to find one with enough depth to clear top. Crow's foot works fine.
  13. ImperialCrown
    18,340
    2,703
    The OEM hexagonal oil pressure switch/sender has the 'rounded' points that a standard 6-point socket tool won't fit onto.
    A special socket is made for these switches/senders:
    [​IMG]
    [​IMG]
