source for stepper motor
Discussion in 'Dakota, 1998-2013 Durango and Aspen' started by bach4660, Aug 11, 2016.
  1. bach4660
    bach4660 Active Member
    May 11, 2008
    44
    2
    I have the 1990 3.9 litre Dakota and the IAC stepper motor has broken, but can't find replacement. Listed as discontinued, nothing at napa,rockauto etc. Will a different year/model work??
  2. Bob Lincoln
    Jul 10, 2002
    29,868
    3,241
  3. ImperialCrown
    18,221
    2,653
    I see an OEM (Mopar) part# of 4288256. That part is discontinued, but still gets hits on Google.
  4. bach4660
    May 11, 2008
    44
    2
    thanks searching with the part number yielded way better results, and I see rockauto does have them. Appreciate the quick responses
    ImperialCrown likes this.
  5. Peymack91
    Peymack91 Member
    Aug 17, 2016
    42
    I'd like to know as well: Is it visibly broken (how can you tell), or is it a suspicion (why)?
    It seems that the pintle on mine is extended farther than it should be. Is that one of the symptoms of yours?
