Stall and carb backfires
Discussion in 'Other classic cars' started by Davidrad, Aug 20, 2017.
  1. Davidrad
    Davidrad New Member
    Jul 31, 2017
    3
    1
    Hello all
    I went for a pleasure cruise today in my floating cloud of a 76 Coronet. Ran great cold and when at temp. Ran horrible in between. Backfires through the carb and stalls and dies. Once warm I was burning tires on a whim. What do you think, coil?
  2. pt006
    pt006 Active Member
    Dec 24, 2014
    1,291
    498
    I'd guess the choke is opening too fast. Check the heat riser valve too.
    Bob Lincoln likes this.
  3. valiant67
    31,994
    11,561
    Almost certainly carb and not ignition like the coil.
  4. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,559
    249
    It might just need a fast idle adjustment.
  5. valiant67
    31,994
    11,561
    Backfire probably means it's getting lean.
  6. valiant67
    31,994
    11,561
    What engine, What carb: 2bbl or 4bbl? Stock or modified?
  7. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,406
    374
    They were bad for the heat crossover passage in the intake manifold getting plugged up.
    Same symptoms, that is if its a 318/360.
    Thanks
    Randy
  8. Bob Lincoln
    Jul 10, 2002
    29,948
    3,336
    Plugged up passage means slow or no choke opening, which equals rich running.
    I'll bet heat riser is stuck in the cold operation position, pushing too much heat through the passage when it should be closed.
    pt006 likes this.
  9. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,527
    446
    A lot of cars in this time frame had electrical heated choke springs. If riser was stuck wrong or passage plugged, the choke would open up before the area under the carb was heated and you would have "icing". (Temporary lean condition ).
