Starting on a '55 Plymouth Plaza Suburban
Discussion in 'Other classic cars' started by 71Charger_fan, Nov 26, 2016.
  1. 71Charger_fan
    71Charger_fan Active Member
    Aug 1, 2014
    287
    187
    My driver's side floor pans arrived today. After the heat breaks and when it's not raining, I'll take it to the body shop for an estimate because I've never learned to weld.
    Bearhawke, hemirunner426 and saltydog like this.
  2. 71Charger_fan
    Aug 1, 2014
    287
    187
    Today, I changed the differential lube again. It still came out thick and black. I may have to change it one more time before winter.
  3. hemirunner426
    Mar 19, 2013
    700
    445
    Nice to see that you are changing the floor pans.That's the proper way to do things.Hopefully the surrounding metal that supports the floor pans isn't rotten.
  4. dana44
    Ad-Free Member
    Jun 17, 2002
    19,343
    1,249
    Yep, always better to replace than to cover up. As far as welding goes, even a novice can tackle little things like this, it is actually a good place to practice. There are some rather good 110v gas shield wire welders (Miller and Lincoln are the best from my limited experience) and are available for a reasonable price (couple hundred bucks). Do some quick practice on a couple pieces of sheetmetal to butt weld them together to get the right heat (not melt through by being too hot), and the nice thing is, you don't need to do long welds, but a two second spot, move around a lot and at least five inches from the previous spot, and do it again, then spot between the spots, and keep going. Prevents warping, gives you practice, and is actually pretty fun to learn/teach yourself this way, and the money spent for a whole welder and small bottle of nitrogen (I don't care for the flux welding wire myself, the nitrogen gas shield is worth the few extra bucks for cleanliness), will pay for itself pver paying someone else to do it for you, and you still have the welder.
    stroudtom likes this.
  5. hemirunner426
    Mar 19, 2013
    700
    445
    Right on,it is called STITCH welding..Hard part is when the old metal you are welding too isn't perfect..I use the flux core wire.
  6. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,610
    385
    Use Argon/CO2, not Nitrogen
  7. dana44
    Ad-Free Member
    Jun 17, 2002
    19,343
    1,249
    I guess that is personal taste, I always used nitrogen for steel since that is what I was taught, and some like flux, I don't care for the excess work to clean it afterwards being a necessary step to weld.
  8. CudaPete
    Ad-Free Member
    Jun 18, 2003
    4,610
    385
    C25 (75%Ar/25%CO2) will give the best results when welding thin mild steel.
  9. 71Charger_fan
    Aug 1, 2014
    287
    187
    Today, I pulled the front seat out so that I could finally dispose of what was left of the disgusting carpet that was in the car. I was happy to see that the floors under and behind the seat weren't too bad. A little POR-15 and fiberglass and they'll be fine. It's not worth replacing the pans for a few small holes.
    Plaza passenger floor.jpg Plaza passenger floor (2).jpg Plaza passenger floor (3).jpg
  10. dana44
    Ad-Free Member
    Jun 17, 2002
    19,343
    1,249
    That's pretty good. POR 15 is pretty good stuff, locks things together pretty well, and you are right, pinholes and that one small rust spot isn't that bad.
  11. 71Charger_fan
    Aug 1, 2014
    287
    187
    I put a second coat of POR and a little more fiberglass on today. Time to move to the section behind the rear seat mount.
  12. 71Charger_fan
    Aug 1, 2014
    287
    187
    I started refinishing the sheet metal side trim for the front bench. The color blue someone had painted these things was fugly.
    Bearhawke likes this.
  13. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,604
    335
    Smart aleck alert here: when that 1955 Plaza was ordered new; the 'rust out' option was not checked. :p
  14. 71Charger_fan
    Aug 1, 2014
    287
    187
    I refinished the seat side trim to match the dash color scheme. I'll eventually redo the seats in a white/black combo. Plaza seat side panels.jpg Plaza seat side panels (2).jpg Plaza seat side panels (3).jpg
    saltydog likes this.
  15. 71Charger_fan
    Aug 1, 2014
    287
    187
    I cleaned up the passenger floor under the back seat. While there was plenty of surface rust, there were no perforations. I suspect much of what corrosion there was was from rodent urine given the size of the mouse nests that were in that seat cushion. I just gave it a coat of POR-15 to seal it. Next, moving on to the driver's side rear. Plaza passenger floor rear.jpg
    saltydog and dana44 like this.
  16. 71Charger_fan
    Aug 1, 2014
    287
    187
    Today, I cleaned up the driver's side floor under the back seat. It was very solid back there. Lots of surface rust, but nothing deep. A good coat of POR-15 and I'll move on to the driver's side rear footwell.
  17. 71Charger_fan
    Aug 1, 2014
    287
    187
    Today, I cleaned up and coated the driver's side rear foot footwell. There were a lot of small rust holes in this area so I generously spread fiberglass cloth around to make sure I got them all.
  18. 71Charger_fan
    Aug 1, 2014
    287
    187
    I ran out of grey POR-15 and had to second coat the driver's side rear seat floor pan in black. So, I went ahead and third coated all three foot wells in black. I'll get the front seat back in tomorrow and probably roll over to a local cruise night (assuming it's not raining). Plaza floor pan.jpg
  19. Bearhawke
    Jun 18, 2003
    13,604
    335
    Def lookin' good there. :)
  20. 71Charger_fan
    Aug 1, 2014
    287
    187
    At some point, probably after Halloween, I'll take it to the body shop and get that driver footwell patched.
