Starting on a '55 Plymouth Plaza Suburban
Discussion in 'Other classic cars' started by 71Charger_fan, Nov 26, 2016.
  1. 71Charger_fan
    71Charger_fan Active Member
    Aug 1, 2014
    288
    187
    Between Hershey and Ebay, I've accumulated a few emblems for an eventual repaint. Even though my car didn't have a Suburban emblem, I think I'll add one just so the Chevy folks can scratch their heads at cruise-ins.
  2. 71Charger_fan
    Aug 1, 2014
    288
    187
    I'm working on assembling a front suspension rebuild kit without having to resort to any of the Chinese stuff being sold now.
    saltydog and hemirunner426 like this.
  3. 71Charger_fan
    Aug 1, 2014
    288
    187
    After rewiring the 1955 Plymouth Plaza Suburban from 6V positive ground to 12V negative ground, I was still left with a 6V heater blower motor. Yesterday, I switched that out using a 4 Seasons Unimotor. I should have measured how far off the mounting plate the fan sat as I had to install/remove/install a few times to get the fan set to the proper depth, but, other than that, it went pretty smoothly. The bushing supplied with the motor makes up for the shaft being too narrow for the hole in the fan. I had to file down one end of the bushing to get it to slip into the fan. I had to make the black lead positive and ground the red lead to get it to turn in the proper direction for the Plymouth. I also had to clip off the studs on the fan side as they otherwise would have hit the back of the fan.
    Plaza Blower Motor.jpg Plaza Blower Motor (2).jpg Plaza Blower Motor (7).jpg Plaza Blower Motor (3).jpg Plaza Blower Motor (4).jpg
  4. 71Charger_fan
    Aug 1, 2014
    288
    187
  5. dana44
    Ad-Free Member
    Jun 17, 2002
    19,345
    1,249
    She works, and that is the important stuff. Good job.
    Bearhawke likes this.
  6. 71Charger_fan
    Aug 1, 2014
    288
    187
    Today, I decided to try and figure out why my cowl vent won't open all the way. While poking around under the dash, I realized the bottom of the heater box was packed with dirt. The only way to get it out was to pull the heater box off the cowl. I still haven't gotten to the bottom of why the cowl vent won't open all the way.
  7. 71Charger_fan
    Aug 1, 2014
    288
    187
    I got the cowl vent out today and successfully snapped off all three screws. Go big or go home. The hinge is well and truly stuck. It's soaking in PB Blaster now. I took a piece of scrap wood and, with a small ball pein, gave it a few sharp taps to see if it would magically break free. It didn't. Hopefully, given enough penetrant and time, it'll move. If I can get any movement at all, it'll help work the penetrating oil in and hopefully restore its range of motion.
  8. 71Charger_fan
    Aug 1, 2014
    288
    187
    I also removed the insulation pad from the heater box and dug out the accumulated dirt and mud with a screw driver. Next, I'll give it a good scrubbing with soap and water, then clean and POR-15 the metal plate. I'll probably get some Thermo-Tec to replace the insulation.
    saltydog likes this.
  9. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,604
    335
    Go big or go home! You're work in getting your 'burban roadworthy qualifies as the former. :)
  10. 71Charger_fan
    Aug 1, 2014
    288
    187
    Thanks to 56D500boy over at ForwardLook.net for tipping me to this inexpensive MerCruiser replacement part to replace my worn out cowl vent rod bellows.
  11. 71Charger_fan
    Aug 1, 2014
    288
    187
    I did get two out of the three snapped off screws out today. The one in the middle still won't budge.
  12. 71Charger_fan
    Aug 1, 2014
    288
    187
    Today, I wire brushed the back side of the cowl vent and the steel plate in the heater box and gave them each a coat of POR-15.
    I was quite happy to have been able to get some movement on the cowl vent hinge. With the heater box out, it's relatively easy to reach in there with a small pry bar and move it. I got a little movement, sprayed it with more PB B'laster, waited a while, then moved it back. It's still nowhere near having its full range of motion, but any movement is encouraging.
  13. 71Charger_fan
    Aug 1, 2014
    288
    187
    I took the propane torch to the third cowl vent screw and it finally came out. I was a little worried when a few wisps of smoke came from the defroster vent inside the car, but all seems okay.
  14. 71Charger_fan
    Aug 1, 2014
    288
    187
    The front of the underside of the cowl vent was pretty heavily rusted. Today, I wire brushed and sanded it, then sealed that surface with some POR-15. If only the hinge was bolted in instead of welded in. It would be nice to be able to strip and coat that.
  15. 71Charger_fan
    Aug 1, 2014
    288
    187
    Plaza Fuel Sender (9).jpg I've come to realize that, with the unique shape of the wagon's fuel tank, I really needed the wagon fuel sender hooked up to the original wagon gauge. So, many dollars later, I have an NOS one.
  16. 71Charger_fan
    Aug 1, 2014
    288
    187
    I'm also continuing to collect old, NOS suspension parts trying to avoid Chinesium components as much as possible.
  17. 71Charger_fan
    Aug 1, 2014
    288
    187
    The hinge has loosened enough that I can now move it to the fully closed position. A bag of #10-24 button-head cap screws came today. They're a little long, but they'll work.
  18. 85lebaront2
    Jun 24, 2017
    116
    27
    Looking good! I am glad you are able to find some good NOS parts, they will be a lot better than most aftermarket replacements. When I had a 1955 Packard I was able to locate a bunch of NOS stuff for it. Interesting note, Packard wire was hypalon insulated even in 1955, Packard Wire and Cable was snapped up by GM as their wire was so superior to what everyone else used. BTW, it was positive ground 12V, the only American car that was like that.
  19. 71Charger_fan
    Aug 1, 2014
    288
    187
    Today, I moved and sprayed the hinge some more and made new insulation for the heater box.
    saltydog, JA Cumbo and Bearhawke like this.
  20. 71Charger_fan
    Aug 1, 2014
    288
    187
    Well crap. I guess it was inevitable.
