Steering 'u joint coupling' - #55351218
Discussion in 'Dakota, 1998-2013 Durango and Aspen' started by TM1963, Jul 6, 2017.
  1. TM1963
    TM1963 Active Member
    Sep 14, 2004
    291
    8
    Looking for mopar part# 55351218, or ideas on refurbishing existing. Appears to be noisy/binding occasionally when turning.
  2. TM1963
    Sep 14, 2004
    291
    8
    Thank you!
  3. TM1963
    Sep 14, 2004
    291
    8
    Update - moparpartsoverstock - indicated via email, "these parts have been discontinued by Chrysler and we can no longer get."
    I have found a few (used) about 200 miles out (1 way) - via car-part.com ... day trip?
    *edit - appears '96 will also fit. Changes were made in '97?
    is '95 2WD 318
    #4 TM1963, Sep 10, 2017
  4. ImperialCrown
    18,229
    2,657
    The main cause of these steering joints binding up is because the coupling runs right next to the exhaust manifold. After a few years the grease in the slip joint and u-joints gets cooked. The same steering coupling issue happens on other cars and trucks.
    Hopefully you can find a good one.
    I used to temporarily free them by soaking the shaft/joints in a bucket of old motor oil and working the joints repeatedly until it freed up. Deceptive steering 'feel' can be dangerous, especially on black ice, etc.
    1995-1996 2WD w/pwr steering should work. There are other (older) Mopar part numbers that would also work: (4773645; 4773646; 4773647; 4773649; 52079244).
    55351218 was the latest version.
