AF: Storage (short-term/long-term) for Wagon | Allpar Forums
Discussion in 'EEK! - Every Extended-K Car' started by ChryslerTC1986, Jan 3, 2020.
  1. ChryslerTC1986
    Aug 19, 2019
    34
    4
    I was curious if the gurus here have any insights as to the best way to store a K through winter in am unheated, covered garage -- I bought me some moth balls and bedazzled the interior with them in their own containers as well as in the engine compartment. I also plugged my tail-pipe with steel-wool because I had some on hand.
    Overkill? Pointless? The K will only really be in storage until Mid-April
    What are some major points of concern during storage?
    Any locations in particular to be aware of to ensure the prevention of rodent inhabitants?
    What do you guys do with your K-cars when they are in storage?
    Thanks!
  2. valiant67
    valiant67 ...
    35,685
    17,682
    Besides rodents, humidity and temperature change can be a problem.
    The car should be stored with a fresh oil change and any fuel should be treated so it doesn't spoil.
    chuzz likes this.
  3. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    7,604
    729
    I'd also add to not engage the parking brake. Sometimes they'll freeze.
    Doug D likes this.
  4. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    13,959
    3,337
    Might want to put the vehicle on jack stands so the tires don't flat spot. Definitely add Sta-Bil (fuel stabilizer).
  5. ImperialCrown
    ImperialCrown Moderator
    20,646
    3,947
    Will the battery be kept in it over the winter? I generally put the convertible on the charger for a few hours every 2nd weekend so that the battery doesn't discharge and freeze.
    Is seed or pet food stored in the garage as well? Rodents love this stuff and I have had to empty air cleaners and remove heater blower motors for clean up.
    Rodents can destroy an interior and wiring. The larger ones chew hoses. Moth balls or strong peppermint may deter them.
    ChryslerTC1986 and Doug D like this.
  6. ChryslerTC1986
    Aug 19, 2019
    34
    4
    Ill look into the oil thing, it might be clean enough since I changed it less than 5,000 mi ago. If it is highly advisable that I do so, I will.
    Imperial, The battery doesnt necessarily need to stay in-place during the winter. I can keep it inside if need be - but I do have a charger so I can keep it charged bi-weekly.
    As for food storage in the garage, I am a recent tenant here so I'll look around the shared garage and see if I find anything. I do know that me and the landlord keep the trash in there (covered) but there is a small compost there - so food sources are in vicinity.
    Do you think its best to put traps down around the vehicle? bait or no bait?
    Any essential places in the engine compartment I should put deterrents (such as moth balls or essential oils).
  7. valiant67
    valiant67 ...
    35,685
    17,682
    Fresh oil right before storage is best. Used oil will be more acidic.
    Doug D likes this.
  8. neon98rt
    neon98rt Well-Known Member
    Feb 18, 2011
    724
    24
    i have a car bag i can sell you. Indoor use only. zips up with dry packs inside that are reusable .
  9. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    34,038
    18,796
    I overinflate the tires to avoid flat spots, and drive it now and then as well (jack stands would be ideal if I had room but the garage is barely wider than the car and I can reach one side or the other). Gasoline stabilizer. I disconnect the battery rather than trickling it, partly because it's not my garage.
