Strange O.P. light
Discussion in 'PT Cruiser' started by ragtop, Aug 5, 2017.
  1. ragtop
    ragtop New Member
    Jul 6, 2017
    3
    I've got an 05 touring with a stage -3 upgrade and my oil light stays on at 1st startup cold or hot.Shut it off and restart and light goes out. New o p sending unit same reaction oil is at correct level correct filter. anyone ever have this problem?
    18,339
    2,702
    Any fault codes? It may not be low oil pressure, but it is trying to tell you something.
  3. ragtop
    ragtop New Member
    Jul 6, 2017
    3
    Yes It has a P-0038 code but I believe it is unrelated as this is an O2 sensor code high voltage,but I may be wrong in asuming that?
  4. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,824
    471
    As for the O.P. problem, check the wire going from the o.p. switch to the PCM. Some have reported that oil actually travels up this wire to the PCM and breaks the connection. It can be cleaned and will start working again. If not that, then I'd take that ops back where I got it and try another one. Especially if you got it from Autozone.
  5. ImperialCrown
    18,339
    2,702
    The switch also relies on a ground through the threads to the block. Allow a metal-to-metal contact (i.e.- no sealers or tapes).
    The P0038 may light the amber 'ck eng' light, but should have nothing to do with the o.p. light.
    The o.p. switch goes to the PCM first and then is bussed over to the instrument cluster. The PCM is seeing a problem with the circuit or the PCM itself is having a problem.
    The o.p. signal isn't directly to the dash light/gauge like the old days.
    Bob Lincoln likes this.
