AF: Sunroof on the move | Allpar Forums
Sunroof on the move
Discussion in 'LH: Large Cars, 1993-2004' started by movinyou, Jul 2, 2018.
  1. movinyou
    movinyou Active Member
    May 25, 2003
    216
    17
    Hello all and Happy Independence Day, My ' 99 LHS has developed a bit of a problem with the sunroof in that one corner has worked loose and it will not tighten up. Does any body know if there is a metal or nylon insert in the glass frame for the screw to thread into? It moves around enough where it pops a bit when semis pass going the other direction. Any hints? Thanks
    ImperialCrown Moderator
    21,196
    4,399
  3. movinyou
    May 25, 2003
    216
    17
    Mr I. C., You are not kidding. I have access to your picture and one from another factory m anuel you sent me a long time ago and they show nothing as far as the bolts that hold that glass panel in. I don't want to seal it up because it still works an I still use it. I can only guess the assembly it bolts into is nylon. Guess I'll have to do a little G.I. engineering on this one. Thanks for the info.
    ImperialCrown likes this.
  4. Tomguy
    Tomguy Well-Known Member
    Oct 4, 2011
    1,240
    935
    When I close my doors, I can see my sunroof "Pop" up a bit. You sure what you're seeing isn't just normal?
