AF: Suspect Thermostat issue | Allpar Forums
Discussion in '1995-2017 FWD Sedans, Coupes' started by captn, Jan 8, 2020.
  1. captn
    captn Active Member
    Jan 10, 2003
    151
    9
    2011, 200 Pentastar 3.6... Have had problem since purchasing the vehicle with lack of heat.
    The engine feels cool after a run and the temp gauge takes forever to show a 1/3 and heat from ducts is not nearly as hot as other vehicles I've owned.
    I think I read that a replacement thermostat is 180 degrees and I sure the engine is not getting that hot.
    Using a laser temp indicator where would I measure the temp and what should it read?
    Any suggestions please....
  2. Bob Lincoln
    Jul 10, 2002
    31,881
    5,195
    It's a 195F thermostat, per the Factory Service Manual.
    Are both heater hoses hot when engine is 'warmed up'? They should be.
    Check fault codes with the key dance method (turn key to ON-OFF-ON-OFF-ON all within 5 seconds, and leave on. Odometer should display any stored fault codes and then the word "dONe"
  3. valiant67
    valiant67 ...
    36,665
    19,407
    I don't know the trim level of the car, but if it's got the display in the center of the cluster, you can scroll through there and it should have an engine temperature reading.
    And I agree with Bob, it's a 195 or so thermostat.
  4. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    4,532
    1,122
    Have you checked for diagnostic codes in the PCM (powertrain control module) related to engine coolant temperature? If you have a code P0128, thermostat rationality, that would indicate a thermostat partially stuck open and not maintaining proper coolant temperature. This would affect heater output warmth. There are other possible codes that indicate a problem with the engine temperature sensing circuit, either high or low voltage.
    Next check the output from the heater ducts. Thoroughly warm the engine and check after a few miles of driving. Idle engine. Set HVAC temperature control to full HOT. Set mode to floor outlet. Check temperature at floor outlet.
    Ambient temperature 60 deg F -- minimum floor outlet temperature 130 deg F
    ambient temperature 90 deg F -- minimum floor outlet temperature 136 deg F.
    No specification could be found for floor outlet temperature at lower ambient temperatures but you can extrapolate from data given. At 30 deg F ambient I would expect a floor outlet temperature no less than 124 deg F.
    Do you have dual zone temperature control in the HVAC? If YES do you feel the same temperature for both driver and passenger side? A significant difference would indicate a problem in the zone controls of the HVAC.
    I would suggest you remove the thermostat and check it. Here is a picture of the thermostat situated in its housing. Notice that there are plastic fingers that hold the unit in place. If one of the fingers has broken or deformed due to heat, it may not allow the thermostat to close properly and regulate engine temperature accordingly.
    If the thermostat is satisfactory or you have replaced it and you still have the inadequate cabin heating issue, check the inlet and outlet heater hoses at the firewall. The outlet should be warm and just slightly cooler than the inlet. After the engine is thoroughly warmed up and running for an extended period of time, you should NOT be able to touch and hold the inlet and / or outlet heater hoses for more than 1 - 2 seconds. Hoses cool to the touch indicate a flow problem which cold be a plugged heater core that is restricting circulation.
    Final area to check is you may have a HVAC blend door that is not moving properly. At the full HOT position for temperature control, an actuator is allowing some cold outside area to enter the HVAC plenum and bypass the heater core.
    I checked several vendors of replacement thermostats for the 3.6 V6 and it appears OEM standard issue is 203 deg F. Interesting discrepancy but this probably is not the issue at hand.
    tomit likes this.
  5. captn
    captn Active Member
    Jan 10, 2003
    151
    9
    Thank you AllanC for lots of good info and have ordered the Dorman thermo housing from Amz for $10. I hope I did the right thing, there is a MAHLE housing for $23 which looks identical, but was told it kisses the water as it passes thru.
    Bob's key dance method worked except for after showing a series of numbers (one being P0128) I went into the house to get a pen and now will not show the numbers just after 10 seconds shows dONe, could I have reset it by mistake? ...Reference to Valaint67 I have the display in the center of the cluster, could you please explain how to get to read out the engine stats. Thanks for everyone help.
  6. captn
    captn Active Member
    Jan 10, 2003
    151
    9
    Please could you explain the procedure to get the engine stats readout on the center display. Many thanks..
  7. valiant67
    valiant67 ...
    36,665
    19,407
    If it is available it will be detailed in your owners manual. It’s possible they didn’t offer that in 2011. I didn’t realize the car was that old.
  8. captn
    captn Active Member
    Jan 10, 2003
    151
    9
    OLD! .... It's the newest car I've owned LOL
  9. andybuzz2u
    andybuzz2u Active Member
    Mar 23, 2004
    56
    7
    IMG_0900.JPG IMG_0898.JPG Those cheap thin finned radiator and heater cores always have a nasty habit of gunking up and stopping up, I would flush the heater core, then pressurize and look for leaks and see what you get before doing anything else. My neighbor brought a 2014 200 sedan new. last year his heater stopped working, not an overly big deal as where in the south and winter temps usually run 55-62, with the occasional 39-44 for a few days, he had 62 thousand odd miles on the car. First thing I did was a dye and pressure test finding no leaks I flushed the heater core and pink mucus looking stuff kept blowing out, then some brown looking mucus, so I gave him the bad news, the heater core is plugged up, anyways he got the parts and I replaced it for him, while I was at it a quick inspection revealed the same was happening in the radiator so I had him buy another one. Long story short that Mopar 5 year 100,000-mile coolant is a joke, I filled it back up with some good old green.
    #9 andybuzz2u, Jan 27, 2020
