AF: Switching out my '90 D150 sweptline for and '82 Utililine short bed | Allpar Forums
Discussion in 'Projects, mods, restoration' started by JOHN P SIMPSON, Sep 24, 2020.
  1. JOHN P SIMPSON
    JOHN P SIMPSON New Member
    Sep 24, 2020
    3
    Looking for box parts to buy or swap for restoration of my '90 sweptline to a step-side. Also any advice on accomplishing this would be much appreciated.
  2. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    6,019
    735
    What bed length do you have now?
  3. JOHN P SIMPSON
    Sep 24, 2020
    3
    6'7". I have read that the chasis is the same for both versions.
  4. Adventurer55
    Adventurer55 Well-Known Member
    Nov 9, 2015
    3,413
    4,437
    They used a Utiline bed as it was called basically unchanged until 85. Unless there is something different because of a tank change going to fuel injection, I would think this would be a bolt on, if you can find a good bed.
  5. 68RT
    Aug 8, 2003
    6,019
    735
    I believe you have a 6 foot 5 inch per specs on a 115 inch or 133 wheelbase (Club cab). Utiline beds had fuel inlet in fender and that might be an issue. Both are 1st gen but I would look at bed mounting bolt spacing, bolt to front of bed, and bed to middle of wheel opening. If those areas match, should work.
  6. JOHN P SIMPSON
    Sep 24, 2020
    3
    Thank you, seems finding the bed, or just the side panels to rebuild a bed is going to be the biggest challenge.
