T/a active intake on charger Daytona hood?
Discussion in 'Challenger, 300, Magnum, Charger' started by sickboy, Dec 28, 2017.
  1. sickboy
    sickboy Well-Known Member
    Feb 28, 2011
    440
    352
    The new t/a hood has intake ducting to the conical air filter. It seems there is a sleight difference in the air box between the two models, the charger has a gap in the front. Not too worried about a good seal, as it’s cold air as well.
    I’m curious if the ducting will fit the Daytona, mostly to keep water from infiltrating the engine bay, but also to clean up the under side of the hood. It’s glaringly unfinished. I could block it off, but this route is more pleasing.
    Also if anyone knows of a trim piece to clean it up, please let me know
