AF: The 2018 Jeep Wrangler JL status thread | Page 65 | Allpar Forums
Discussion in 'Mopar / FCA News' started by 12soldier, Aug 8, 2015.
  1. Denzien
    Denzien Active Member
    Jul 15, 2014
    193
    62
  2. Mike V.
    Jan 24, 2008
    26,427
    22,138
  3. WXman
    WXman Active Member
    Oct 28, 2014
    898
    1,115
    Is it just me, or does that look like they chopped up the bed of a Ram pickup and cobbled that together?
  4. Mike V.
    Jan 24, 2008
    26,427
    22,138
    Yes, as discussed in the other thread. It's a mule put together for testing purposes.
    That bed is not what will be installed when the vehicle debuts. It will probably be something similar to the AEV Brute.
    Mike
    Ruptured Duck and MoparDanno like this.
  5. redriderbob
    redriderbob Mopar Guru!
    Supporter
    Feb 22, 2004
    12,761
    23,186
    [​IMG]
    Wrangler JL will for sure have a TFT screen between the speed and tach, note this mule is carrying the new Chrysler steering wheel.
  6. Ruptured Duck
    Ruptured Duck Active Member
    Jan 2, 2015
    1,161
    1,801
    You can also see the new angle of the windshield. look at the side window glass and the door structure at the A-pillar and compare it to a current JK.
  7. redriderbob
    Supporter
    Feb 22, 2004
    12,761
    23,186
    [​IMG]
    Pretty sure its using the same body... in that spy shot
    Mike V. likes this.
  8. CherokeeVision
    Dec 9, 2004
    5,919
    2,824
    I'm hoping for less of a toy look for the JL. I would prefer less bright work and less curves around knobs and vents.
    Current looks great for catching dust and dirt and making it hard to clean.
  9. oh2o
    May 19, 2001
    3,522
    4,004
    The center stack is a little less "cluttered", as they have removed the 2 vents and switches just below the radio.
    Mike V. likes this.
  10. K-9
    K-9 Well-Known Member
    Jan 2, 2013
    158
    145
    Isn't that for the new 8.4" UConnect, though?
  11. oh2o
    May 19, 2001
    3,522
    4,004
    The new radio only required a little more room, it's pretty much in the same location.
    wilbur and Mike V. like this.
  12. xjgary
    xjgary Well-Known Member
    Jan 15, 2012
    400
    252
    Yes! On vintage Jeeps you just pulled the rubber plugs in the floor pan and hosed it out. Easy to clean after a hard dirty day on the trail. Even my Cherokee XJ has the plugs. I seriously doubt you can do that on the new ones without ruining the electronics.
  13. dmcdonald
    dmcdonald Well-Known Member
    Jun 19, 2012
    893
    958
    JKs still have the plugs.
  14. Ruptured Duck
    Jan 2, 2015
    1,161
    1,801
    It is so this tells you a lot about whats under the skin. If you take that same angle shot of the steering wheel and look at both the window glass and the door frame (at a-pillar) there is an increase in the angle.
  15. D0C
    D0C Well-Known Member
    Oct 2, 2003
    2,415
    57
    Did they remove them or move them?
    I would hate for them to have dropped the number of vents to two. Four is perfect
    Summer = one vent per armpit
    Winter = one vent per hand on the steering wheel
    I hope they also keep the round vent design, those things are great for aiming the air anywhere you want
    wtxiceman and xjgary like this.
  16. JKU12
    JKU12 Well-Known Member
    Feb 23, 2013
    3,295
    4,094
    Nope it's just fine. Gets nice and dirty and cleans up well.
    TripleT and Bionicrooster like this.
  17. JKU12
    Feb 23, 2013
    3,295
    4,094
    Incorrect.
    dmcdonald, Ruptured Duck and Mike V. like this.
  18. Bionicrooster
    Bionicrooster Well-Known Member
    Jan 22, 2008
    209
    138
    Yep, my 2010 JK gets rained in / hosed out all the time. After hunting season I usually pull the carpets, nail them to my fence, and pressure wash them, the pressure wash out the inside of the jeep. A little common sense is all it takes not to ruin anything :)
    JKU12, dmcdonald and Ruptured Duck like this.
  19. CherokeeVision
    Dec 9, 2004
    5,919
    2,824
    Five vents is the proper number. On a hot Texas summer I still miss that driver crotch vent on that old 75 Buick LeSabre. Now if I had only been Scottish I could have worn a kilt back then.
    Zagnut27, D0C, Mike V. and 1 other person like this.
  20. oh2o
    May 19, 2001
    3,522
    4,004
    Moved them, still round.
