The future of Wrangler
Discussion in 'Rumors and Speculation' started by CherokeeVision, Sep 21, 2017.
  1. dmcdonald
    dmcdonald Active Member
    Jun 19, 2012
    871
    912
    I have owned a wide variety CJs, YJs, TJs, XJs and JKs. In fact, I have over 30 straight years where I have at least one Jeep in my possession. I have used each and every one of them in a wide range of conditions, on and off road. Unfortunately, your comments will only perpetuate a myth that AWD systems can't be as capable or even more capable depending on the situation (only time will tell in the JL). Off road is not a narrow set of criteria or conditions that any one person here gets to define. Your comments also completely ignore the fact that the Wrangler offers suspension, lifestyle, and too many other advantages that the GC or and Honda do not regardless of part time or full time systems. While I personally may not feel inclined to buy an AWD version, we don't get to decide what someone else needs or wants to best suit their application and situation! The Wrangler is a true all purpose vehicle, especially since the demise of the XJ.
    MJAB, ScramFan, DarkSky and 2 others like this.
  2. Mike V.
    Jan 24, 2008
    24,635
    18,178
    Agreed it will be interesting, although the system that will be used is a very capable system.
    One thing to note, the full time 4 wheel drive system for the JL Wrangler will is not “all wheel drive”. It utilizes an electronically controlled, two speed transfer case with 50/50 or 40/60 split and unlike AWD, 100% of the power is not sent to a single axle or wheel.
    Calling the system “all wheel drive” is not accurate.
    Mike
    #22 Mike V., Sep 21, 2017
    DarkSky and link3721 like this.
  3. jimboy
    jimboy Well-Known Member
    Dec 7, 2006
    909
    620
    Well people here are channelling Mopar Norm! This thread has devolved into a Jeep discussion, like the ones he was involved with always did! I miss that man.
  4. Mike V.
    Jan 24, 2008
    24,635
    18,178
    See comment above, JL will not have an “all wheel drive” system.
    Mike
  5. Mike V.
    Jan 24, 2008
    24,635
    18,178
    I had to say something... it’s not right to call it all wheel drive.
    Mike
    jimboy and BASONE88 like this.
  6. Erik Latranyi
    Aug 20, 2003
    10,819
    10,149
    The meaning of a word depends on if you are talking to an engineer or a marketing person.
  7. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,460
    3,701
    I think AWD and 4WD tend to get used interchangeably for right or wrong. But I think in this case, at least from my own usage, it was because I wasn't sure what type of system to actually refer to it as. But whatever its called, I'm interested to find out more when its finally officially revealed.
    aldo90731 likes this.
  8. aldo90731
    Jul 6, 2010
    5,737
    9,207
    Very true. One key thing you will need to be watchful for when shopping for a used JL.
    Judas Shuttlesworth and danbek like this.
  9. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,460
    3,701
    But seriously...I think we've taken a major wrong turn somewhere and are trudging through the weeds. How about those new CUV's coming from Chrysler! I'm eager to see what they will actually look like and not like a camo-mule-refugee from the Beverly Hillbillies. :)
    BASONE88 and DarkSky like this.
  10. Mike V.
    Jan 24, 2008
    24,635
    18,178
    Erik, that’s not true. Full time 4 wheel drive and all wheel drive are two completely different systems. Jeep is marketing the system as full time 4 wheel drive on the JL because that is what it is, not all wheel drive.
    I’m sorry, but calling it “all wheel drive”, like you and @aldo90731 did, is not correct. Doing so only perpetuates confusion and misunderstanding of how the system works.
    Sorry for going off topic everyone, but this is Allpar and we should hold ourselves to a higher standard.
    Mike
    #30 Mike V., Sep 22, 2017
    danbek, dmcdonald and DarkSky like this.
  11. nastijeep
    nastijeep Active Member
    Sep 6, 2017
    65
    78
    I have a compass sold as a 4x4. it is listed as AWD unless I select 4x4. 4x4 is quite capable in snowy conditions. what am I missing in my understanding of the drive capabilities? how is the compass 4x4 so different than my 2nd gen Dakota 4x4?
  12. Mike V.
    Jan 24, 2008
    24,635
    18,178
    Assuming your Compass is 2007-2017, it is AWD but uses a lower axle gear ratio in conjunction with an alternate program for the CVT to simulate the benefits of a 19:1 low-range transfer case for off-road use. There is no transfer case in the system, like your Dakota 4x4 has.
    If you want to discuss it further, it is probably best to start a thread in the Jeep Compass section rather than continue the discussion here where it is off topic. Future Chrysler’s will have AWD available including the use of seperate electric propulsion’s systems for the rear axle.
    Hope that helps. :)
    Mike
    #32 Mike V., Sep 22, 2017
    nastijeep likes this.
  13. link3721
    Oct 18, 2012
    928
    619
    Cool, I think this is the first time the new JL system has been explained. Sounds like a good setup.
  14. Mike V.
    Jan 24, 2008
    24,635
    18,178
    Welcome. :)
    Mike
  15. aldo90731
    Jul 6, 2010
    5,737
    9,207
    See, but you are assuming we will be getting a "legendary" SUV with a "legendary" 4WD system with "legendary" off-road capabilities.
    Excuse my skepticism, but I still have to see Jeep, under FCA, develop something NEW that truly expands off-road capability. The truly offroad-worthy vehicles now in FCA's lineup, like Wrangler and Power Wagon, repackage "legendary" parts, like lockers and disconnects, already in existence. The only "legendary" new offroad thing I am seeing is FCA push AWD to "legendary" limits.
    Most likely, we will end up getting another "legendary" ABS-based AWD system with a "legendary" rotary dial and some "legendary" name like "Insta-Trac". And we will have "legendary" debates about how this latest AWD really is as good as a true legendary 4WD system.
    Then Chrysler will get the exact "legendary" AWD but more appropriately named "Safety-Trac", with a rotary dial and a "Mall" setting no less, so we can debate forever how truly convenient it is.
    #35 aldo90731, Sep 22, 2017
  16. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,460
    3,701
    While I understand the sentiment...I'm extremely skeptical with regards to anything that FCA attempts with Jeep...and I say a prayer daily to the Jeep Gods above that they won't screw it up...at least not Wrangler anyways...I'm willing to withhold judgement until we actually see how it performs. If it's what you think or worse, then I'll have my pitchfork sharpened and my torches appropriately lit. Until then, I've got two energetic toddlers who will ABSOLUTELY use a pitchfork and torch against me. :)
    Doug D and aldo90731 like this.
  17. aldo90731
    Jul 6, 2010
    5,737
    9,207
    Make that a future Chrysler pitchfork, to bring it back onto topic. :D
    Zagnut27 likes this.
  18. nastijeep
    Sep 6, 2017
    65
    78
    would the pentastar emblem be replaced with a pentafork?
    BASONE88, Zagnut27 and aldo90731 like this.
  19. Judas Shuttlesworth
    Judas Shuttlesworth Active Member
    Aug 29, 2016
    58
    111
    It will probably affect resale by putting a premium on those Wranglers with a mechanical 4wd system.
  20. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,460
    3,701
    That might go well with a Hellcat or Demon...but those are Dodges. It might go well on a Chrysler...um...well...maybe...a Pacifica??...maybe as a Trident instead?? Oh never mind. :D
