AF: The new (to us) Compass. | Allpar Forums
Discussion in 'Compacts: Renegade, Patriot, Compass, Caliber' started by bguy, Nov 14, 2014.
  1. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,779
    165
    Well folks we purchased a nicely cared for 2011 Compass North Edition 4x4. Just under 51,000km on the clock. It's grey with a grey interior. Has 2.4 with the CVT auto. I've driven it for about 30km with a short put down the TCH. Reading about the CVT I knew exactly what to expect. Pick a light throttle setting and the engine doesn't rev out, the car just accelerates steady. I found it quite interesting and would probably have a bit of fun experimenting with the best throttle/acceleration ratio.
    One thing I can't quite discern is the 4x4 system. It seems to be full time 4x4 but there's a 4x4 button. Does this lock the transfer case or engage some limited slip device?
    Thanks for reading.
  2. gforce2002
    gforce2002 Well-Known Member
    Oct 31, 2003
    2,106
    1,374
    You're right about the CVT - if you don't hammer the gas it's actually quite livable and just goes about its business.
    All AWD/4WD Compasses and Patriots are normally in AWD mode - the "4x4" button (or lever, really) locks/couples the front and rear shafts so both axles are active full-time. It does make a significant difference in slippery or loose rock conditions.
  3. ImperialCrown
    ImperialCrown Moderator
    21,120
    4,303
    There are a couple of neat videos explaining the Freedom Drive I and II:
    I have the CVT in the Caliber. The 'feel' takes some getting used to (I found it unpleasant at first).
    The electronic throttle has no throttle cable. With an untrained foot, it will seem to race and bog.
    The VVT selects the optimum valve timing and the CVT selects the optimum gear ratio.
    bguy likes this.
  4. dodgeismycar
    dodgeismycar Well-Known Member
    Mar 21, 2012
    615
    467
    On the subject of CVT, my 2012 Compass has about 21K on the odometer,.
    What should I do about transmission service at 24K, anything?
    Thanks.
  5. Stratuscaster
    Stratuscaster Vaguely badass...
    Jul 5, 2001
    43,889
    6,642
    If under warranty, I'd bring it to the dealer for the scheduled service.
  6. dodgeismycar
    Mar 21, 2012
    615
    467
    Thanks.
    I believe that the fluids should be drained,etc, correct or is it too soon?
  7. link3721
    Oct 18, 2012
    1,317
    1,148
    24k miles? The manual doesn't have any service on the cvt until at least 100k miles (unless they've changed something since my '09). However, I had a noise start at 50k that went away once I had the dealer do the transmission service. From what I've read on other Patriot forums, the 50k mile transmission service is recommended for the cvt as a preventative measure.
  8. dodgeismycar
    Mar 21, 2012
    615
    467
    Thank you so much!
  9. Cornupenuria
    Cornupenuria Well-Known Member
    May 23, 2013
    749
    161
    Keeping the A/C condenser coils and/or radiator (especially the lower third or fourth) free of dirt and insects seems to go a long way toward preventing transmission from overheating on long trips in hot weather. I use a shop vac with a crevice nozzle. It seems the transmission can overheat with the engine temperature remaining in normal range.
