Tire pressure sensors
Discussion in 'Repairs, Maintenance, Help' started by captn, Dec 19, 2017.
  1. captn
    captn Active Member
    Jan 10, 2003
    124
    8
    Hi all, I was under the impression the tire pressure sensors for each tire measures the rotation of the tire, more pressure equals slower rotation. RPM's of the tire is proportional to PSI. Can anyone tell me if this is correct. Many thanks...
  2. valiant67
    31,980
    11,552
    Incorrect, it measures pressure.
  3. ImperialCrown
    18,344
    2,704
    Tire speeds that are measured by the individual ABS sensors is a base GM system. Other manufacturers might also use it.
    It can be accurate except if worn tires are rotated that can throw it off. Gradual tire wear shouldn't trigger it.
  4. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    975
    330
    I hate those things.
    CudaPete likes this.
