AF: Tire size limit on Challenger and Charger- why so skinny? | Allpar Forums
Discussion in 'New Challenger, 300, Magnum, Charger' started by MRGTX, Mar 26, 2015.
  1. MRGTX
    MRGTX Well-Known Member
    Feb 23, 2006
    160
    67
    I have been shopping around Challenger Scat Packs and I was puzzled to see a 480hp car with 245s...I recall some facts about why the Challengers (and Chargers) ended up with narrow wheel wells but the facts are escaping me.
    Is this considered a major handicap for these cars? How big can you go in the aftermarket?
    IIRC, the Hellcats come with 275s at least, right?
    My relatively wimpy Mustang can easily accommodate 315s in the rear and 305s in the front (wth carefully selected offsets)...doesn't seem fair! FWIW, I run 285s on mine currently and still wish for more.
  2. tazdevil
    tazdevil Member
    Nov 14, 2009
    560
    61
    Partly because narrow means less rolling resistance and better fuel economy.
    TheMan likes this.
  3. valiant67
    valiant67 ...
    36,672
    19,412
    The wheelwells were pretty much determined before there was a performance version of the car as I understand it.
    It's been mentioned before and the cost to add more tire (through factory body modifications) would have been very large.
    TheMan likes this.
  4. moparroy
    moparroy Active Member
    Oct 22, 2004
    830
    20
    Keep in mind force of friction is independent of surface area (laws of physics) - its only really a matter of rubber compound
  5. tazdevil
    tazdevil Member
    Nov 14, 2009
    560
    61
    Don't know where you found that law. You seem to say that any skinny tire will corner or roll same as a wide tire. NAHAH!
    The compound of the rubber has much to do with rolling resistance. Tire manufacturers can reduce rolling resistance with harder compound, but then performance in wet or snow is reduced dramatically.
  6. AHBGuru
    AHBGuru Active Member
    Mar 22, 2015
    533
    375
    The Pursuits got a 245/55/18 option in late 2014, for fleets that have a mix of Dodge and Ford (very common). Most of the Charger Pursuits have used the thinner 225/60/18 size since 2006, with Continental, Goodyear, and Firestone changing the compounds over the years to make the W-rated tires stick.
    I am currently using the 245/55/18's on my 2013 Charger, and it feels perfect. Ride is still very good.
    With the weight of the Hellcats, my concern would be load and speed rating, considering the amount of heat that could build up in the sidewalls of the cars going well in excess of even the fastest of regular SRT cars. Since the Chally Hellcat is more the straight line champ, it probably isn't as prominent of a concern than what one would (or should) have with the Charger. A little higher sidewall gives more cushion, and likely offers more of an expanded cooling surface. at 205-210 mph, nobody wants a blowout. Chrysler has long been a company that truly excelled at building a vehicle to handle very high speeds.
    wtxiceman likes this.
  7. moparroy
    Oct 22, 2004
    830
    20
    Cornering is much more than just a matter of friction and skinnier tires tend to be a harder compound and thus a lower coefficient of friction = lower force as well. Racing slicks are wider so they can use a softer compound so the weight of the vehicle can be supported with lower pressure in a softer compound tire. All I am saying is don't be fooled that a wider tire in and of itself will improve your friction (thinking mainly for acceleration). The law is certainly true - I recall that from high school physics - but certainly again from first year engineering mechanics. According to Wiki its known as Amontons' Second Law but I don't recall if that is the name - too long ago.
  8. TheMan
    TheMan What color are the clouds in your world?
    Sep 19, 2002
    30,506
    6,002
    Correct. The force is one of shear between the "tooth" of the road surface and the tire compound matrix.
  9. Mike V.
    Jan 24, 2008
    26,427
    22,139
    The wheel wells is not really the issue. The design of the rear suspension. The location of the rear sway bar inhibits larger tires from the factory.
    Will tires larger than 275 fit, yes it is possible.
    Mike
  10. valiant67
    valiant67 ...
    36,672
    19,412
    Yep - everything has a cost. One of the costs of IRS is the limited tire room.
  11. ImperialCrown
    ImperialCrown Moderator
    21,192
    4,392
    Did the visionaries foresee a Hellcat when these cars were developed ~15 years ago?
    They knew a V8 would be offered, so they made room for that.
    Viper was developed and designed as a supercar from the beginning.
    You can't just 'tub' a unibody LX without great expense, difficulty and compromise. Maybe it was easier to hack them up in the rear leaf spring/BOF days for straight line drag strip duty. It is just not practical for a well-mannered general daily driver like a Hellcat with a rear seat and trunk.
