AF: Torque Converter symptoms | Allpar Forums
Discussion in 'Vans' started by Scrounge, Sep 22, 2017.
  1. Scrounge
    Scrounge Got parts?
    Apr 30, 2009
    2,472
    524
    An ad for a '95 Ram van in Texas with a 6-cylinder engine and about 120K miles reports that the torque converter needs to be replaced, and says $300 worth of parts will fix it. What would the transmission be doing (or not doing) to indicate that the torque converter is bad? And is this a common problem with full-sized vans of this era?
  2. Bob Lincoln
    Jul 10, 2002
    31,725
    4,961
    If it ran very low on fluid for extended time, the torque converter could be warped and causing slippage, or the pump could be burned out.
  3. Scrounge
    Scrounge Got parts?
    Apr 30, 2009
    2,472
    524
    Thanks. If it's still available when I return to Texas, I'll check for slippage. But running low on fluid for too long might cause other damage, so I wonder if the trans might have more problems that need overhaul or replacement.
    And now, I also wonder if the owner removed the torque converter for another vehicle, and the one for the van is just missing.
  4. ImperialCrown
    ImperialCrown Moderator
    20,945
    4,164
    You may have noise, vibration or shudder. If the torque converter has to be accessed, you might as well recondition the transmission clutches and check the cooler flow, etc while it is out.
