NewsNew Pacifica trim to hit sweet spot? • Does the Demon stop faster than the Camaro ZL1? • More Waymo Pacificas; public to test
Torqueflite 727 no reverse when warmed up possible servo issue
Discussion in 'Pre-1994 trucks, commercial vehicles' started by upser145, Apr 14, 2017.
  1. upser145
    upser145 New Member
    I have a TF 727 and the reverse will hesitate then pop into gear and kind of work if its cold but once it warms up i pretty much lose all reverse. I have properly adjusted the reverse band in the transmission so I think the next step would be to check the servo. I've never done much transmission work myself and was wondering if there was a walkthrough or something out there somebody could point me to to assist me in checking the low reverse servo. Thanks in advance guys
  2. upser145
    upser145 New Member
    Ive been planning on a rebuild soon anyway but if its only a servo or something i could do myself without dropping the trans i figure i should atleast try'
  3. geraldg
    geraldg Active Member Ad-Free Member
    623
    what year and model is the car ?
  4. dana44
    dana44 Well-Known Member Ad-Free Member
    1,329
    I had this happen to my Charger once. Yes, it was the servo, tore it down and found the spring had broken and the retaining clip had come off so no pressure could be held. wind it up and it would work just a little bit. Not a difficult fix, but you have to drop the pan if you do it in the car, fluid likes to drip a bit on you, so messy.
  5. upser145
    upser145 New Member
    1988 dodge w150
  6. PCRMike
    PCRMike Active Member
    727
    Did you make sure the bands are adjusted correctly?
