AF: tps sensor | Allpar Forums
tps sensor
Discussion in 'EEK! - Every Extended-K Car' started by willrappold, Sep 14, 2016.
  1. willrappold
    willrappold Active Member
    Jan 23, 2013
    57
    3
    I have a question regarding my tps sensor on my 85 reliant se 2.2l tbi car. My tps sensor on the car looks like the ones for the carburetor-ed models not the fuel injected models, what do i do? Did the early tbi cars use the same sensor as carburetor-ed? Pick of what my sensor looks like on rock auto
    1985 PLYMOUTH RELIANT 2.2L 135cid L4 Throttle Position Sensor (TPS) | RockAuto
    thanks for help.
  2. Rickorino
    Rickorino Well-Known Member
    Jan 23, 2005
    747
    132
    I never heard of a TPS on a carburator, it has a mechanical accellerator pump and a TPS is basically an electronic version of an accellerator pump. Select the one which matches the appearance of your original. One has a plug inserted into it and the other has a harness. Should be easy. If you have an ohm meter, you should check yours to be sure it is bad. Also very easy.
  3. valiant67
    valiant67 ...
    36,781
    19,594
    Feedback carbs did have a TPS. It monitored the opening of the carb and reported it to the computer, did nothing more than that.
    I've never compared one of them to what a TPS looks like on the TBI cars.
  4. bamman
    bamman Part Connoisseur
    Apr 22, 2003
    2,431
    28
    Your TPS sensor should look like this:
    RockAuto
