NewsDemon has a freakin’ TransBrake • Pritchett’s Challenger Drag Pak isn’t a Demon • Ram Longhorn to match trailers
Trouble with Dart trunk popping open randomly?
Discussion in 'Dodge Dart / Viaggio' started by AmbassadorSST, Mar 16, 2017.
  1. AmbassadorSST
    AmbassadorSST New Member
    1
    I bought a 2016 Dart GT as a demo with 3000 miles on it in May of last year. About 2 weeks after purchasing the Dart, the trunk would pop open after placing the car in park at random times. It doesn't do it every time, its just super annoying. I've took it to the dealership several times; they seem befuddled and have yet to fix the issue. It's maddening, especially when it's raining, or really cold outside.
    Have any other Dart or FCA owners have had any issues like this with their vehicles?
  2. Christopher
    Christopher Socially Unacceptable Level III Supporter
    165
    There is a TSB for it on the Chargers. I don't have it handy though. I had that happening with my Charger. My brother has not had an issue with his Dart.
  3. AmbassadorSST
    1
    Thanks for the reply. So it could be an FCA issue, not just specifically a Dart issue?
    It seems like an easy fix, I can't understand why the dealership seems incapable of fixing it. o_O
  4. Christopher
    165
    I don't know enough about the Dart. With the Charger the trunk release button in the would get water in it and cause it to open. If the Dart has a button to open the trunk, it *might* be related. In the Charger it is integrated into the CHMBL. It is the button on the left. The backup camera is on the right.
    11-14 Dodge Charger New Center High Mounted Stop Lamp Brake Light Mopar Oem | eBay (at http://www.ebay.com/itm/11-14-Dodge-Charger-New-Center-High-Mounted-Stop-Lamp-Brake-Light-Mopar-Oem-/351883989691 )
  5. ImperialCrown
    2,200
    Intermittent electrical can be very frustrating to verify if it doesn't act up at the time that the technician is looking at it.
    The more clues that you can provide for them may make it easier to know where to look.
    'Only when going into Park at times' is an important clue.
    Keep working with them and keep all your paperwork (repair orders).
    Maybe a STAR case with the factory can be opened for the car?
  6. DBY2014
    DBY2014 Member
    272
    Never had that issue with my Dart and don't remember any complaints about it either.
    The factory that doesn't produce Darts any more? LOL
  7. DBY2014
    DBY2014 Member
    272
  8. AmbassadorSST
    1
    It does have a button, and most of the time it doesn't work. I tell them about that every time I take it to the dealership, and they look at me like I'm speaking freaking Portuguese.
    Most of the time it does it right when you crank up the car...after you drive it then put it in park it rarely does it. You can also hear it clicking a bunch of times like a button is being pressed constantly.
  9. AmbassadorSST
    1
    I'm to the point I want them to replace every component that has to do with the trunk release...not sure if the warranty would cover all that though.
  10. ImperialCrown
    2,200
    Is yours a 2016 model year? I found similar bulletins for older Darts. Make sure that the BCM is at the latest software version:
    There is a TSB # 08-042-12A for passive entry vehicles intermittently releasing the deck lid latch.
    There is a TSB # 08-001-13 for deck lid latch won't release.
    There is a STAR case for 'Deck lid won't latch or stay closed -or- electrically opens while walking away (passive entry vehicles)'.
    The inside emergency trunk release T-handle can release the deck lid if it is being slightly pulled on if not placed in its stowage follower.
    If you have no luck communicating with the service advisor, I would ask to meet and discuss your issue with the service manager. Bring your receipts with you and ask what the next step is.
  11. AmbassadorSST
    1
    Yea, it's a 2016.
    Ill ask them about the software next time I take it in. I tried messing with the emergency trunk release thinking that may of been the problem, but it didn't seem like it was out of place or loose.
    Thanks for the info.
  12. ImperialCrown
    2,200
    Does your Dart have the 'Passive Entry' option where it will recognize the key transponder and unlock your car as you approach and lock it as you walk away?
  13. AmbassadorSST
    1
    When I touch the door handle it will unlock it, but to lock it I either use the key fob or button on the door handle.
    ImperialCrown likes this.
  14. ImperialCrown
    2,200
    OK, that must be the Dart's Passive Entry. That is mentioned as the malfunctioning option possibly causing the deck-lid release.
    Dave Z likes this.
  15. Dave Z
    Dave Z It's me, Dave Staff Member Supporter
    12,747
    While we're on this topic...
    If you do NOT have the passive entry, is there a way to get into the trunk without using the remote button or key fob?
