AF: turn signal switch needed!! | Allpar Forums
Discussion in 'EEK! - Every Extended-K Car' started by willrappold, Feb 17, 2016.
  1. willrappold
    willrappold Active Member
    Jan 23, 2013
    57
    3
    I have an 85 reliant and I need the turn signal switch the part has been discontinued the number is 4221680. The replacement you can buy from rockauto, autozone, do not fit the car. I cant find one I any junkyards in my area. Also tried to repair the original but It cant be fixed. Any help would be greatly appreciated. thanks.
  2. valiant67
    valiant67 ...
    36,781
    19,594
    It should be a pretty standard part. They didn't change very often. However, 4221680 is a new number for 1985, replacing 4221337 use din 1984 (both are non-tilt, non-cornering light part numbers).
  3. marty mopar
    marty mopar Well-Known Member
    Jan 16, 2008
    555
    32
    from the 1985 part book:
    signal switch (w/o cruise control)
    4221 339 1 M,Z SWITCH, Turn Signal & Hazard Warning
    4221 680 PDCVJET w/o Cornering Lamp, w/o Tilt Strg.
    4221 682 BFG,HK w/o Cornering Lamp, w/o Tilt Strg.
    4221 304 PDCVJET w/o Cornering Lamp, w/Tilt Strg. Sag.#7841454
    4221 485 HK w/Tilt Strg. Sag.#7844423
    4221 485 B,F,G w/o Cornering Lamp, w/Tilt Strg.,Sag.#7844423
    4221 305 PD,CVJE w/Cornering Lamp, w/Tilt Strg.Sag.#7841455
    4221 681 PD,CVJE w/Cornering Lamp, w/o Tilt Strg.
    4019 782 1 ALL ARM, Sig. Switch w/Tilt Strg
    I called my Mopar dealer
    4221680 is superseded to or by: 4373048,4373049,4221682
    4221337 is superseded to or by: 4221328 I show it fits 1982-83 w/o Cornering Lamp, w/o Tilt Strg.
    so according to Mopar they don't interchange
    I do stock 4221337 NOS 85.00 plus shipping
    www.arizonaparts.com
    my contact info is there.
