AF: Vertical play in rear hub 1992 B250 | Allpar Forums
Discussion in 'Vans' started by John MacDonald, May 14, 2015.
  1. John MacDonald
    May 14, 2015
    1
    Van has only done 15000miles and has minor vertical play in rear hub. Is this normal?
  2. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,760
    159
    You mean you can lift the side axle by the flange with the wheel and drum removed? That's normal. The axle shaft itself is the inner bearing surface so you'll need to take the center cover off and slip it out to inspect. If it's not noisy I wouldn't worry about it.
