AF: wheels???? | Allpar Forums
wheels????
Discussion in 'All other classic cars' started by Kevino, Oct 13, 2016.
  1. Kevino
    Kevino New Member
    Sep 25, 2016
    8
    1
    trying to figure out a cheap way of getting around the 14" wheel on my new yorker. does anyone know what alternatives there are? i'd run the 14 but having a hard time finding a radial tire thats close to the stock 9.00-14 bias ply size. i'd love to run a wide white wall but not wanting to spend a grand on tires.
  2. valiant67
    valiant67 ...
    36,171
    18,532
    Most likely later model 15" wheels from a Diplomat or Fifth Avenue will bolt right on.
    Bearhawke likes this.
  3. ImperialCrown
    ImperialCrown Moderator
    20,954
    4,164
  4. rapidtrans
    rapidtrans Well-Known Member
    Jul 29, 2005
    1,682
    932
    A 235/75x14 is close to our diameter.
    American Classic Tires has this size with a 1" w.w. They may be pricey over $200 each.
  5. saltydog
    saltydog Well-Known Member
    Mar 26, 2010
    2,372
    485
    I just bought some Hankook 215/75 R14's form my 64' New Yorker. Under $400 for a set of 4 at Walmart.
  6. rapidtrans
    Jul 29, 2005
    1,682
    932
    That would be the closest diameter to my original Monaco tire.
    Originals were 8.55/78x14's. The math works out pretty close.
  7. saltydog
    Mar 26, 2010
    2,372
    485
    Here is a pic of the tire
    [​IMG]
  8. Kevino
    Kevino New Member
    Sep 25, 2016
    8
    1
    well i picked up these beauts this weekend. now i'm in the process of changing the lh wheel studs on the drivers side to rh threads. its turning out to be a bit of chore. good thing is i have a friend with a hydraulic press, hoping this will make short work of it all. i'm anxious to put them on and go for a cruise!!!!
    saltydog likes this.
  9. saltydog
    Mar 26, 2010
    2,372
    485
    Nice looking wheel!
  10. rapidtrans
    Jul 29, 2005
    1,682
    932
    FWIW.
    Here is my solution.
    Wasn’t happy with the looks of the 14” wheels and tires on my Monaco.
    A 14” w.w. is too hard to find and look too skinny on the original 5.5” wide rims.
    So I found a guy that makes 15” stock rims in any width, and offset, you want then adapts them to accept the stock 14” wheel cover.
    Sooo, I went with a 7” wide rim and 225x70/15 tires. Tires are common in 15” sizes for well under$100 each.
    I found the wider rim fills the wheel well very nicely with just a 225 width tire.
    Here you can see the 1/2” spacer tacked inside the rim to accept the wheel cover.
    The cost of the wheels were a little more than brand new Magnums and all the trim pieces.
    But hey, everyone puts Magnums on their Mopar. I prefer these original spinner wheelcovers.
