AF: Who gets the new six? | Allpar Forums
Discussion in 'Mopar / FCA News' started by Dave Z, Jan 31, 2018.
  1. Dave Z
    Dave Z It's me, Dave
    Jan 23, 2001
    34,928
    20,600
    It’s still some time out, but a GME-based turbo six is almost certainly coming. Where is it going to be made?
    Fortunately, FCA has no shortage of relatively new or renovated plants in Michigan.
    [​IMG]
    Dundee is a twin-plant complex, but currently there’s just one shift working in one plant, making “World Gasoline Engine” (WGE) four-cylinders. Trenton, another twin-plant complex, is busily making both those four-cylinders and the Pentastar V6, along with parts and blocks. Then there’s Mack Avenue, another twin-plant complex, currently engaged in making Pentastar V6 engines and parts.
    [​IMG]
    Mack’s advantages include being closest to most of the plants that would use the GME T6, and going from “World Class Manufacturing” bronze to silver in just 15 months, “an unprecedented achievement,” according to FCA. If the engine is to be used in Grand Cherokees, it helps that Mack Avenue is very close to the Jefferson Avenue Assembly Plant, too.
    [​IMG]
    There is an added complication: FCA will need many more 2-liter turbocharged four-cylinders soon, and the old WGE fours will be phased out sooner or later.
    If this engine is meant for high-volume production, there may well be two or more lines, in two different plants.
    Timing for the GME T6 is still unknown, with some sources claiming it’s at least two years out, and others saying it’s closer. Two years seems like a reasonable median, but we do not know FCA’s schedule, so if it takes four years, that does not mean it was delayed. There has been no official announcement of the GME T6’s existence, but there have been many supporting clues.
    [​IMG]
    Regardless, it seems unlikely that FCA will either build a new plant or send production of this new engine off to Mexico. One could argue for using some of Italy’s spare capacity, but so far, FCA has re-used existing plants even if it had to gut the interior and start over. That’s good news for FCA’s many union workers, and the communities they support.
    Read the whole post here.
  2. James A
    James A Active Member
    May 3, 2016
    769
    553
    Excited for this motor. Looking forward to the details on power out puts
  3. redriderbob
    redriderbob Mopar Guru!
    Supporter
    Feb 22, 2004
    12,765
    23,203
  4. thebluegoat
    thebluegoat Active Member
    Nov 27, 2014
    191
    193
  5. dodgeatheart
    dodgeatheart Not THAT guy again!
    Feb 1, 2004
    1,099
    746
    Fa18 hornet?
  6. GasAxe
    GasAxe Well-Known Member
    May 12, 2008
    6,726
    10,230
    Powered by the new Dodge Photoshop doesn't exactly roll off the tongue.
    VoiceOfReason, Zagnut27 and suzq044 like this.
  7. CherokeeVision
    Dec 9, 2004
    5,936
    2,864
    Viper was an unofficial name for the F-16 before Falcon was chosen.
    I don't know if that means anything in relation to that photo.
    VoiceOfReason and Moparian like this.
  8. Moparian
    Moparian Well-Known Member
    May 16, 2012
    4,758
    2,940
    Those who fly it still call it Viper.
    VoiceOfReason likes this.
  9. DAGAR
    DAGAR Active Member
    Sep 21, 2014
    1,998
    3,190
    those are F16 Falcons (Vipers) not F18s
    VoiceOfReason and dodgeatheart like this.
  10. erhemi
    erhemi Well-Known Member
    Oct 22, 2004
    716
    361
    The Viper plant? Conner Ave?
  11. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    5,483
    10,757
    It has as much power as an F16? :p
  12. freshforged
    freshforged Well-Known Member
    Dec 4, 2003
    2,974
    2,541
    As much as an infinite number of F16s.
    VoiceOfReason, James A and Zagnut27 like this.
  13. Tin Man 2
    Tin Man 2 Active Member
    Dec 14, 2017
    1,057
    1,501
    I would think the new 6 and 4 would be built in the same plant, isn't this engine family designed to use different numbers of the same parts as much as possible? Much like Mound Rd. Engine used to make the 318 and the cut down v6 version on the same fixtures and machining tools. I would think you would want to be flexible as to product mix to account for demand.
    superduckie5000 likes this.
  14. Roryn44
    Roryn44 Well-Known Member
    Jun 3, 2013
    88
    44
    More jets than our airforce in that picture ahahahah
  15. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    5,483
    10,757
    That is super AWESOME!!! Now if Wrangler gets that AND VTOL capability, then POOF! My brain just exploded. :p:D
  16. somber
    somber 370,000 miles
    Sep 10, 2014
    1,326
    1,883
    Or will it cost as much as an F16?
    VoiceOfReason and Zagnut27 like this.
  17. HotCarNut
    HotCarNut Defender of Reality
    Mar 24, 2009
    2,927
    2,767
    Hmmmm....does that mean the debut for this engine would be a high-hp application in the Viper replacement (a la Ford’s high-hp Ecoboost V6 in the Ford GT)?
  18. freshforged
    Dec 4, 2003
    2,974
    2,541
    Viper replacement is way off yet. No way the GME T6 debuts in that. Next year or the year after unless all hell breaks loose.
  19. vipergg
    vipergg Well-Known Member
    Apr 8, 2002
    2,682
    828
    I'm hoping it is a I6 motor and not a V6 . I6's are noticeably smoother than a V6 .
    James A likes this.
  20. HotCarNut
    Mar 24, 2009
    2,927
    2,767
    Yes,
    and they also take up a lot more space, especially with turbo-charging. From a packaging standpoint, they are probably limited to longitudinal mounting applications (think L-series, RAM 1500, Jeep Wrangler and GC/Durango). The rumored Wagoneer/Grand Wagoneer would probably also be able to use them.
