AF: Why are 2 cycle engines so hard to start?? | Allpar Forums
Discussion in 'Off Topic But Still Civil' started by voiceofstl, May 25, 2017.
  1. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    2,370
    1,203
    Its that time of the year again, to bring out the weed eater and chain saw.
    You would think after 100 years of 2 stroke engines the darn things would be easy to start by now. The instructions on some of them are crazy..,,pump primer 7 times , put on full choke and pull rope 3 times then prime 2 more times and put on half choke .ect..ect...
    And no its not me, everyone I know has the same problem.
    solutions???
  2. Bob Lincoln
    Jul 10, 2002
    31,883
    5,198
    Not everyone has the same problem. I have all hand tools, human-powered.
    They start first try, every time. :p
  3. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    7,986
    1,073
    I have a 12 year old Ryobi string trimmer with the 49cc engine. I simply put gas in it, prime it the required 7 times with the bulb and crank it . It USUALLY starts on the 3rd or 4th pull. Maybe you should try a shot of starting fluid every time. That always works. You may have a small crack or hole in one of the fuel lines on the carburetor. That's the ONLY thing I've had to replace on mine in 12 years. The only reason I found it is because it leaked out a half tank of gas overnight last year.
  4. schelled
    schelled Well-Known Member
    May 11, 2006
    189
    61
    First thing to do is put in fresh gas and a new sparkplug....my string trimmer starts on the 2nd or 3rd pull every time, prime it twice choke and away it goes....if you are having to prime it so many times you probably have a leaking crank seal or a fuel line crack or a poor quality trimmer.....get a stihl or some other type of high quality trimmer and saw...I have a 30 year old stihl saw that will start immediately even if it has sat for several years
    DC-93 likes this.
  5. Dave Z
    Dave Z It's me, Dave
    Jan 23, 2001
    34,940
    20,627
    I am having this problem with my generator — I apparently need to clean out the carburetor. Be nice if I could just spray something in, but it's a matter of taking the fuel bowl apart... bleh.
    I use electric trimmers and lawnmowers to avoid that nonsense. Much quieter, do pretty much the same job with pretty much the same effort, last longer, and no need to always go out and get gasoline (or pull on a cord).
    Tony K and voiceofstl like this.
  6. chuzz
    Apr 3, 2004
    7,986
    1,073
    Hey Dave, what size line does your electric trimmer use? And how often do you have to replace the bump feed? I'm on my 3rd bump feed head and they're getting harder to find every few years. The so-called UNIVERSAL fits don't work correctly.
  7. DC-93
    DC-93 Well-Known Member
    May 1, 2014
    3,172
    2,067
    Usually improper winter storage adds to the "hard start" the following year.
    Always drain all the fuel before putting the item away for the winter!
    This includes the tank, lines and carb bowl.
    Ask me how I know. lol...
    Works the same way for the snow blower!!
    Change the plug, oil, air filter yearly. My old snow blower starts first pull, every time.
  8. voiceofstl
    Jan 15, 2010
    2,370
    1,203
    I GAVE UP! Got a ryobi 40 volt battery trimmer. ITS GREAT!
  9. rapidtrans
    rapidtrans Well-Known Member
    Jul 29, 2005
    1,747
    1,013
    I’ll be replacing my 2 stroke lawn tools with battery powered tools too. The battery life, power and quiet operation beats eliminates the gas mix and hard starting.
    I use WD40 as a starting fluid for hard to start 2 strokers.
    DC-93 and Tony K like this.
  10. voiceofstl
    Jan 15, 2010
    2,370
    1,203
    I;ve used my new rybiy.its a 40 volt, there more powerful expensive models. My ryobi is almost a powerful as my old gas one. and it suits my uesesd just fine.
  11. Tony K
    Tony K Active Member
    Jan 11, 2019
    872
    1,233
    You have a 30 year old Stihl. I don't mean to badmouth new Stihl products, but those old Stihls were built to last for sure.
    DC-93 likes this.
  12. LouJC
    LouJC Active Member
    Oct 7, 2014
    1,050
    890
    Around here I’m known as the 2 stroke whisperer. All 4 of mine start right up, the Echos on the 3rd pull the Toro on the first or second. Fuel stabilizer+semi syn or full syn 2 stroke oil...the Toro has a thumping Suzuki 5 hp 2 stroke that’s 22 years old!
    tlc, DC-93 and rapidtrans like this.
  13. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    5,489
    10,768
    I gave up on my old gas string trimmer years ago because I could never get it to run consistently well anymore. I bought a corded string trimmer in a pinch because that was all that was available the day when I just couldn’t take the frequent stalling anymore, and I’ve never looked back. Lugging around extension cords is a bit of a PITA, but I’ve managed for several years now...if it dies maybe I’ll switch to battery powered. I’ve really come to enjoy electric tools. Only my push mower is gas now.
  14. page2171
    page2171 Well-Known Member
    Apr 28, 2007
    1,684
    2,527
    When we bought our house I had to get a new trimmer because my old corded trimmer wasn't going to work with the size of our yard. I went with the 56V EGO line at Home Depot and got a trimmer and leaf blower combo. Couldn't be happier.
  15. rapidtrans
    Jul 29, 2005
    1,747
    1,013
    We found a Mercury Marine Whisperer up near the cottage years ago. We had issues with stalling and this guy set up our outboard on the pontoon just by ear. Twenty five years later and I‘ve never touched the carbs and only replaced the plugs twice. When it started each spring I left it alone. Some guys just have the touch.
    DC-93 and page2171 like this.
  16. voiceofstl
    Jan 15, 2010
    2,370
    1,203
    The EGO is top of the line and If you have alot of trimming to do thats the way to go. The 40 volt ryobi so far is plenty for my needs.
  17. voiceofstl
    Jan 15, 2010
    2,370
    1,203
    I've always thought a corded elecritic would be much more popwerfull then battery. I had the black&decker corded trimmer 10 yrs ago, it was way to weak. My new battery one is almost as strong as a gas trimmer.
  18. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    14,539
    4,016
    No battery powered tools here. I do have a corded electric chain saw (14 in) and a corded electric hedge trimmer. Both have served me well. Otherwise my mower is self-propelled 21 inch gas powered Yard Machine to cut a half acre. I have considered a battery powered mower for my next purchase.
  19. page2171
    Apr 28, 2007
    1,684
    2,527
    I have a half acre with privacy fence on two sides. The battery on the EGO will get all my trimming done if I stay on top of the trimming. If I let it slide for a couple of weeks, then I have to recharge.
    My sister has a smaller place and she got the Ryobi, it works really well for her.
  20. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    5,489
    10,768
    Hmmm, I’ve never had any issues with it lacking power, but it’s only 3 years old or so (It is a Black & Decker). I had a rechargeable B&D that was pretty weak and it was discharged after about 30 minutes or so which made it pretty useless for our last house (3/4 acre with lots of sidewalks and fencing). We now have a slightly smaller yard (.53 acre) with less sidewalk area and less fencing. I may try an actual battery trimmer at some point to see what they’re like by comparison...it would be nice to get rid of the cord, especially if it’s the same or better for power.
