AF: Window gap, how to adjust? | Allpar Forums
Discussion in 'EEK! - Every Extended-K Car' started by iowa-k, May 16, 2020.
  1. iowa-k
    iowa-k Member
    May 13, 2018
    61
    6
    ‘84 convertible. How do I close this gap?
    ImperialCrown Moderator
    20,958
    4,165
    Any excessive glass looseness from channel wear would probably need to be addressed first. Loose glass will stay loose.
    If that is OK, looking at how the glass meets the top seal, does the 1/4 glass need to be moved out at the top or does the drivers glass need to be moved in at the top? Or both?
    The interior trim panel(s) would need to be removed and the glass adjusted. Procedures and illustrations are in the service manual.
    Typically, the in/out jackscrews are at the bottom. Other adjustments may need to be trimmed afterwards also:
    [​IMG]
  3. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    14,318
    3,760
    A good friend of mine just had a new top installed on his '65 Ford Galaxie. As IC mentioned there is a procedure to adjust the windows to align properly. For his Ford it involved removing the door panels to access the adjustment screws.
  4. Dave Z
    Dave Z It's me, Dave
    Jan 23, 2001
    34,654
    20,039
  5. iowa-k
    iowa-k Member
    May 13, 2018
    61
    6
    Glass is tight. Looks easier (and I have done it before) to pull the door panel and try adjusting there first.
