Windshield wipers quit working fan comes on when turn wipers on
Discussion in 'Pre-1994 trucks, commercial vehicles' started by upser145, Apr 27, 2017.
  1. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    I was driving and my windshield wipers suddenly quit working and when i got home i checked the fuse and its good and wipers wont do anything but fan comes on when i turn wipers on
  2. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    not even sure its the fan it sounds like it but im not sure
  3. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,514
    240
    Where does the noise come from? It might be the wiper motor -- if so, a part of the hardware might be broken. If you look under the cowl, you might see the problem.
    But if the noise is elsewhere, and nothing is broken, your switch or wiper motor might need replacing.
  4. Devildodge
    Devildodge Active Member
    Mar 21, 2015
    821
    724
    Sounds like your bushings may have rotted off or it just popped off the motor stud.
    Bob Lincoln likes this.
  5. valiant67
    31,636
    10,867
    I agree - without the linkage attached, the wiper motor sound is very different. It may be nothing more than the white plastic bushings, which are available in the help products. Inexpensive, but it can be a pain working on the linkage on some vehicles.
  6. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    3,130
    399
    You did not indicate specific model Dodge truck nor model year.
    Try this test. Make sure all accessories that generate noise / sound (radio, heater fan, seat belt chime, etc) are turned off. Turn ignition to RUN / ON position but do not start engine. Turn wiper switch to low speed and then high speed. Does the sound change? If YES then the wiper linkage under the cowl area has disconnected from the crank arm on the wiper motor gear reduction. You hear the wiper motor running without any load and it should be noticeable. As others have said there is a plastic bushing / grommet in the linkage arm connection to the wiper motor crank arm.
  7. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    well im stupid it was a bushing i had recentlty replaced that broke that i didnt even suspect since its new
  8. Devildodge
    Mar 21, 2015
    821
    724
    Out of curiosity what for vehicle did we help you with. Darn windshield wiper bushings are a p.i.a.
  9. upser145
    upser145 Member
    Jan 16, 2017
    78
    1
    88 w150 and yes they were
  10. Devildodge
    Mar 21, 2015
    821
    724
    I had them go on my 78 Powerwagon and they just went on my 88 aries sw.
    Cheap fix, but not always so easy.
  11. Meester Beeg
    Meester Beeg Active Member
    Sep 10, 2016
    140
    45
    Somewhat related I replaced a couple bushings and both wiper arms when I replaced the windshield on the 92 Dakota. Dont buy the Dorman replacements. The are soft and the splines strip. I went through two sets in a couple months. Finally I went to the scrapper and got some OEM units and made em purdy.
