Wrangler (rear) Striker Bolt bit size
Discussion in 'Wrangler, CJ, Wagoneer, other traditional Jeeps' started by 1999 White C5 Coupe, Jul 24, 2017.
  1. 1999 White C5 Coupe
    1999 White C5 Coupe Well-Known Member
    Jul 11, 2006
    209
    53
    Does anyone know the bit size (Torx) for the rear door striker bolt on a 2003 Jeep Wrangler Rubicon?
    The rear door rattles and it is apparent that the door does not close flush with the body. I want to loosen and adjust the bolt inward to allow the door to close tighter and flush with the body.
    Thank you.
  2. 1999 White C5 Coupe
    Jul 11, 2006
    209
    53
    Solved: The striker bolt is a T-47 (same as the front caliper bolts for my 2003 Dodge Durango). The latch mechanism bolts (T-30) were loose and the latch could be adjusted.
    (I was unable to edit my original post - not sure why).
